I recently upgrade my router's firmware to 3.0.0.4.376.3861 and I noticed some strange behavior.
So I upgraded the firmware last week because my ISP thought my router wasn't releasing its lease on an IP (had the same IP for 7 months, which isn't normal).
After uploading the firmware file and getting the login prompt, I held the reset button for 5 seconds. After this I reapplied all of my router's settings by hand. This includes changing the username and password to log into the router. After changing all of the settings, I double checked that I could log into the router through the router's IP address.
So here is where things get weird, I logged in again to check what was my public IP and it was the same. So the tech did something on their side. Something like clearing my router, modem and computer's MAC from their routing tables (had to give my router's MAC). After he told me to check, I was able to login to check the public IP and it was the same.
So he gave up and I decided to power off the modem and the router for a week. Today, was the first time I turned on the modem, router and the computer connected to the router since last week. What I had noticed was that my computer's local IP address was different was my manual assignment, which was set last week. So when I tried to access the router (after disconnecting the WAN cable), I couldn't get in with my credentials. I had used the same credentials from last week, which I wrote on note so that I couldn't make mistakes. Even the default admin/admin combo didn't work.
From there I tried every permutation of mixing and matching my custom credentials and the default. Example: newusername/admin, admin/newpassword, newusername/newpassword, admin/admin.
Nothing worked, so I decided to reset the router by holding the reset button for 5 seconds. I reapplied the settings again and confirmed that it works. I can login and my computer is getting the right manual IP.
So does anyone have any insight on how this could have happened? I don't have this router doing anything special other than being a router, so no VPN, no File Sharing or AiCloud. I have the "Enable Web Access from WAN" set to No. I believe I even have UPnP disabled under WAN. There is no one else living with me, so they can't access the router.
As a side note, I have WPS disabled on both frequency and I double checked it in the Web GUI. However, on my phone I used WiFi Analyzer and for my SSID I can see my encryption type as well as WPS. Does that mean WPS is enabled or just that it has the feature? I thought I was going crazy and I saw that the WPS option under Wireless was Off.
