Strange routes to University in Japan?
deanfourie
Hey guys! So I have a question regarding some really strange routes in my routing table.
I recently put my Huawei B818 4G router into bridged mode behind pfSense, which is now my main router. Upon doing so, I notice these static entries that pop in and out of my routing table. They are
163.47.0.1 - acoresw05.metro-cit.ac.jp
163.47.0.2 - aedgesw30.metro-cit.ac.jp
163.47.0.3 - doesn't resolve.
And also I am noticing a route for 163.47.0.0/16.
Now, given that I am routing traffic through a university in Japan, this did strike me as a bit odd.
Your thoughts?
Looking at your routing table - you have manually added the two static router for metro-cit.ac.jp
If you didn't add them - I would suggest that you update/change the password, as someone is adding those routes - one is a gateway route (acoresw05), and the other is a host...
Thanks for the reply. Ok but I cannot delete them. It says that they cannot be deleted.
Plus they are on my WAN interface which is receiving IP via DHCP from ISP
You appear to be using a 4G/LTE router. Are you geographically close to Japan? Is it simply because your mobile operator routes their traffic through Japan?
