Stronger OpenVPN key?
revwatch
Hi guys,
I'm curious if anyone knows how to generate stronger keys for the openvpn service. I turned on the openvpn server on my router and exported a key for my laptop. My laptop connects just fine but I see a warning in the router logs:
WARNING: this cipher's block size is less than 128 bit (64 bit). Consider using a --cipher with a larger block size.
Is there any way to make it larger?
Hi guys,
That has nothing to do with keys, this is because you use the default cipher, which is Blowfish - it uses a 64-bit block size. You need to switch to something like AES-128-CBC instead of using Default.
I should have known better. Thank you for pointing it out!
Probably for the best anyways... not just security, but the speed impact is minimal to a plus perhaps...
(numbers from Raspbian Jessie, note that the Pi2/Pi3 may have features in the CPU that the Cortex-A9 in the Broadcom 4709 might not have)
Pi3 (Cortex-A53)
OpenSSL 1.0.1t  3 May 2016
built on: Fri Sep 23 22:38:09 2016
options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) blowfish(ptr)
compiler: gcc -I. -I.. -I../include  -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -DTERMIO -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -Wl,-z,relro -Wa,--noexecstack -Wall -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DAES_ASM -DGHASH_ASM
blowfish cbc     63867.73k    72246.74k    74448.21k    75290.97k    74320.55k
aes-128 cbc      80615.96k    92460.91k    96452.52k    97122.99k    97512.11k
Pi2 (Cortex-A7)
blowfish cbc     36089.69k    40047.68k    41176.23k    41462.10k    41549.82k
aes-128 cbc      38910.05k    42153.71k    43413.33k    43730.22k    43879.08k
And here's some numbers from another thread - in any event, no good reason to do blowfish these days...
aes-128-cbc is as good as bf-cbc...
RT-AC68U (RMerlin's snapshot numbers on RT-AC68U - Cortex-A9)
OpenSSL 1.0.2g  1 Mar 2016
built on: reproducible build, date unspecified
options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) idea(int) blowfish(ptr)
compiler: arm-brcm-linux-uclibcgnueabi-gcc -I. -I.. -I../include  -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -ffunction-sections -fdata-sections -O3 -Wall -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DAES_ASM -DBSAES_ASM -DGHASH_ASM
The 'numbers' are in 1000s of bytes per second processed.
type             16 bytes     64 bytes    256 bytes   1024 bytes   8192 bytes
blowfish cbc     36915.44k    42434.73k    43879.42k    44380.84k    44518.06k
aes-128 cbc      44942.35k    49098.05k    51060.96k    51337.56k    51464.87k
aes-256 cbc      34033.03k    37076.28k    38205.37k    38533.78k    38704.43k
WRt1900ACv2 - Marvell Armada 385, Cortex-A9 - DD-WRT
OpenSSL 1.0.2e 3 Dec 2015
compiler: ccache arm-openwrt-linux-gcc -I/home/seg/DEV/mvebu/src/router/zlib -L/home/seg/DEV/mvebu/src/router/zlib -I/home/seg/DEV/mvebu/src/router/openssl/crypto -fPIC -I. -I.. -I../include  -DZLIB_SHARED -DZLIB -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -Os -pipe -march=armv7-a -mcpu=cortex-a9 -mtune=cortex-a9 -mfpu=vfpv3-d16 -mfloat-abi=softfp -fno-caller-saves -DASMAES512 -ffunction-sections -fdata-sections -I/home/seg/DEV/mvebu/src/router/zlib -DNDEBUG -DOPENSSL_NO_ERR -DTERMIO  -fomit-frame-pointer -Wall -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DAES_ASM -DBSAES_ASM -DGHASH_ASM
blowfish cbc     29817.64k    31649.17k    32004.52k    32087.16k    32226.45k
aes-128 cbc      51975.55k    56637.65k    58510.21k    58654.72k    58840.41k
aes-256 cbc      40014.20k    42613.78k    43574.53k    43790.68k    43808.09k
