strongswan+ac66u = no port in connection table?
v1k0d3n
So I need to set up a VPN from a Cisco IOS device to my Asus Router. Now, I think this could be done, so I used some the example here: http://www.cisco.com/c/en/us/support/docs/ip/internet-key-exchange-ike/117258-config-l2l.html
...and I'm trying to apply to my scenario. Ok, so it seems to be ok from a configuration standpoint. I added the following to a custom firewall script:
# DESCRIPTION: Allow IPSEC StrongSWAN Connections
iptables -I VPN_TUNNEL_IN -i eth0 -p udp --dport 500 -j ACCEPT
iptables -I VPN_TUNNEL_IN -i eth0 -p 50 -j ACCEPT
iptables -I VPN_TUNNEL_IN -i eth0 -p udp --dport 4500 -j ACCEPT
iptables -I VPN_TUNNEL_OUT -i eth0 -d 0.0.0.0/0 -p udp --dport 500 -j ACCEPT
iptables -I VPN_TUNNEL_OUT -i eth0 -d 0.0.0.0/0 -p 50 -j ACCEPT
iptables -I VPN_TUNNEL_OUT -i eth0 -d 0.0.0.0/0 -p udp --dport 4500 -j ACCEPT
...and here is my [basic] ipsec.conf file located in /opt/etc/:
conn cisco
      left=%defaultroute
      leftsubnet=[local_nets]		#network behind strongswan
      leftid=%defaultroute		#IKEID sent by strongswan
      leftfirewall=yes
      right=[remote_ip]		#IOS outside address
      rightsubnet=[remote_nets]		#network behind IOS
      rightid=[remote_ip]		#IKEID sent by IOS
      auto=add
      ike=aes128-md5-modp1536		#P1: modp1536 = DH group 5
      esp=aes128-sha1			#P2
...and here is the strange part...
no matter what I do, it doesn't seem to show that ipsec is opening the udp ports for ipsec:
udp        0      0 0.0.0.0:137             0.0.0.0:*
udp        0      0 0.0.0.0:138             0.0.0.0:*
udp        0      0 0.0.0.0:9999            0.0.0.0:*
udp        0      0 0.0.0.0:42000           0.0.0.0:*
udp        0      0 0.0.0.0:56510           0.0.0.0:*
udp        0      0 0.0.0.0:5474            0.0.0.0:*
udp        0      0 0.0.0.0:18018           0.0.0.0:*
udp        0      0 0.0.0.0:1900            0.0.0.0:*
udp        0      0 0.0.0.0:38000           0.0.0.0:*
udp        0      0 0.0.0.0:43000           0.0.0.0:*
raw        0      0 0.0.0.0:255             0.0.0.0:*               255
...what am I missing here? also, one other sidenote: someone said that they had a newer version of strongswan than 4.5.3-2. am I missing something or do i have optware/entware installed incorrectly? it doesn't seem to get any newer then this.
admin@RT-AC66R:/tmp/mnt/OPTWARE/asusware/etc# ipkg list | grep swan
strongswan - 4.5.3-2 - A IPsec implementation.
in advance...thanks for your help guys! i appreciate the look and time.
- v1k
