skeal
Part of the Furniture
Good morning:
I've had OVPN Server working on an AX88U an AC68U and an AC1900P all of which worked quite well.
Yesterday I reset all three routers to factory defaults (maintenance), the AX88U is on 386.8 and the others on 386.7_2
Since the router was reset to defaults with just a default OVPN Server setup. I cannot access the router itself but the OVPN shows connected, at the same the VPN Server provides internet access to the connected clients.
Router to router OVPN Server connections and OpenVPN Connect on Android, all fail to open the routers Firmware pages.
I wish the logs showed something but they don't. OVPN shows it's connected in the logs with no problems, and the system log shows no entry at that time slot.
From the clients point of view things work fine. From the network supervisor's view point it's a pain in the butt. Right now I use Teamviewer to gain access on the clients network, through a device.
I guess the questions I have is: Is this related to updates in OVPN of recent? or Is this another outer function going on like the jffs script that runs when OVPN anything is started or stopped? Or am I just not with it here and haven't found the clue?
Please anyone with OVPN Server knowledge better than mine.....HELP PLEASE!
