Stuck On Beta 2
MoInSTL
Downloaded RT-AC86U_384.5_0zip twice for my AC1900. Unzipped it, Rebooted before and after. Giving me the unsuccessful message again.
RT-AC86U_384.5_0_cferom_ubi.w
Since when ac86 is ac1900? Yours pirated?
It's in the readme. Bolded and text color are mine.
Supported Devices
Asuswrt-Merlin is available in two separate branches:
- The original (legacy) Asuswrt-Merlin (up to version 380.xxx)
- The new generation (current) branch (version 382.xxx and newer)
The legacy 380.xx branch is no longer being actively developed.
Support for the RT-N66U and RT-AC66U is being dropped, as
these models will not be available on the new generation code base.
Devices supported on the new generation/current branch (382.xx and newer):
* RT-AC66U_B1 (use the RT-AC68U firmware)
* RT-AC56U
* RT-AC68U, RT-AC68P, RT-AC68UF (including HW revision C1 and E1)
* RT-AC1900 & RT-AC1900P (use the RT-AC68U firmware)
* RT-AC87U
* RT-AC3200
* RT-AC88U
* RT-AC3100
* RT-AC5300
* RT-AC86U
Your first few words .....
"Downloaded RT-AC86U_384.5_0zip twice "
Merlin's instructions are to use the RT-AC68U , NOT the 86U
did you use the AC68 as per the readme, or did you use AC86 as per your original post ?
My bad.
I guess I am a little dyslexic before second cup of coffee. Thanks for the quick replies.
don't worry you are not the only one, I have done that myself in the past.
Supported Devices
* RT-AC56U
* RT-AC87U
* RT-AC3200
* RT-AC88U
* RT-AC3100
* RT-AC5300
* RT-AC86U
Lol... you even highlighted and bold it...
Never ever do firmware flashing when you are sleepy...
