Jan 22 00:10:50 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC68U, emailAddress=me@myhost.mydomain
Jan 22 00:10:50 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, CN=client, emailAddress=me@myhost.mydomain
Jan 22 00:10:50 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 peer info: IV_GUI_VER=net.openvpn.connect.ios_3.1.1-2819
Jan 22 00:10:50 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 peer info: IV_VER=3.git::2ae73415
Jan 22 00:10:50 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 peer info: IV_PLAT=ios
Jan 22 00:10:50 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 peer info: IV_NCP=2
Jan 22 00:10:50 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 peer info: IV_TCPNL=1
Jan 22 00:10:50 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 peer info: IV_PROTO=2
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 PLUGIN_CALL: POST /usr/lib/openvpn-plugin-auth-pam.so/PLUGIN_AUTH_USER_PASS_VERIFY status=0
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 TLS: Username/Password authentication succeeded for username '*****iphone5s'
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 1024 bit RSA
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: 141.226.***.254:5320 [client] Peer Connection Initiated with [AF_INET6]::ffff:141.226.***.254:5320
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: client/141.226.***.254:5320 MULTI_sva: pool returned IPv4=10.8.0.2, IPv6=(Not enabled)
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: client/141.226.***.254:5320 MULTI: Learn: 10.8.0.2 -> client/141.226.***.254:5320
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: client/141.226.***.254:5320 MULTI: primary virtual IP for client/141.226.***.254:5320: 10.8.0.2
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: client/141.226.***.254:5320 PUSH: Received control message: 'PUSH_REQUEST'
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: client/141.226.***.254:5320 SENT CONTROL [client]: 'PUSH_REPLY,route 192.168.10.0 255.255.255.0 vpn_gateway 500,dhcp-option DNS 192.168.10.1,redirect-gateway def1,route-gateway 10.8.0.1,topology subnet,ping 15,ping-restart 60,ifconfig 10.8.0.2 255.255.255.0,peer-id 0,cipher AES-128-GCM' (status=1)
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: client/141.226.***.254:5320 Data Channel: using negotiated cipher 'AES-128-GCM'
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: client/141.226.***.254:5320 Outgoing Data Channel: Cipher 'AES-128-GCM' initialized with 128 bit key
Jan 22 00:10:51 RT-AC68U-C760 ovpn-server1[30622]: client/141.226.***.254:5320 Incoming Data Channel: Cipher 'AES-128-GCM' initialized with 128 bit key
Jan 22 00:10:58 RT-AC68U-C760 ovpn-server1[30622]: client/141.226.***.254:5320 SIGTERM[soft,remote-exit] received, client-instance exiting
Jan 22 00:11:46 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 TLS: Initial packet from [AF_INET]141.226.***.254:5432, sid=baa9d827 0320d6ed
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC68U, emailAddress=me@myhost.mydomain
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, CN=client, emailAddress=me@myhost.mydomain
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 peer info: IV_GUI_VER=net.openvpn.connect.ios_3.1.1-2819
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 peer info: IV_VER=3.git::2ae73415
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 peer info: IV_PLAT=ios
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 peer info: IV_NCP=2
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 peer info: IV_TCPNL=1
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 peer info: IV_PROTO=2
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 PLUGIN_CALL: POST /usr/lib/openvpn-plugin-auth-pam.so/PLUGIN_AUTH_USER_PASS_VERIFY status=0
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 TLS: Username/Password authentication succeeded for username '***ipadpro'
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 1024 bit RSA
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5432 [client] Peer Connection Initiated with [AF_INET]141.226.***.254:5432
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: client/141.226.***.254:5432 MULTI_sva: pool returned IPv4=10.16.0.2, IPv6=(Not enabled)
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: client/141.226.***.254:5432 MULTI: Learn: 10.16.0.2 -> client/141.226.***.254:5432
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: client/141.226.***.254:5432 MULTI: primary virtual IP for client/141.226.***.254:5432: 10.16.0.2
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: client/141.226.***.254:5432 PUSH: Received control message: 'PUSH_REQUEST'
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: client/141.226.***.254:5432 SENT CONTROL [client]: 'PUSH_REPLY,route 192.168.10.0 255.255.255.0 vpn_gateway 500,dhcp-option DNS 192.168.10.1,redirect-gateway def1,route-gateway 10.16.0.1,topology subnet,ping 15,ping-restart 60,ifconfig 10.16.0.2 255.255.255.0,peer-id 0,cipher AES-128-GCM' (status=1)
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: client/141.226.***.254:5432 Data Channel: using negotiated cipher 'AES-128-GCM'
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: client/141.226.***.254:5432 Outgoing Data Channel: Cipher 'AES-128-GCM' initialized with 128 bit key
Jan 22 00:11:47 RT-AC68U-C760 ovpn-server2[28944]: client/141.226.***.254:5432 Incoming Data Channel: Cipher 'AES-128-GCM' initialized with 128 bit key
Jan 22 00:11:54 RT-AC68U-C760 ovpn-server2[28944]: client/141.226.***.254:5432 Connection reset, restarting [0]
Jan 22 00:11:54 RT-AC68U-C760 ovpn-server2[28944]: client/141.226.***.254:5432 SIGUSR1[soft,connection-reset] received, client-instance restarting
Jan 22 00:11:58 RT-AC68U-C760 ovpn-server2[28944]: TCP connection established with [AF_INET]141.226.***.254:5435
Jan 22 00:11:58 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5435 TLS: Initial packet from [AF_INET]141.226.***.254:5435, sid=19d99329 37c94355
Jan 22 00:11:58 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5435 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC68U, emailAddress=me@myhost.mydomain
Jan 22 00:11:58 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5435 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, CN=client, emailAddress=me@myhost.mydomain
Jan 22 00:11:58 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5435 peer info: IV_GUI_VER=net.openvpn.connect.ios_3.1.1-2819
Jan 22 00:11:58 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5435 peer info: IV_VER=3.git::2ae73415
Jan 22 00:11:58 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5435 peer info: IV_PLAT=ios
Jan 22 00:11:58 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5435 peer info: IV_NCP=2
Jan 22 00:11:58 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5435 peer info: IV_TCPNL=1
Jan 22 00:11:58 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5435 peer info: IV_PROTO=2
Jan 22 00:11:58 RT-AC68U-C760 ovpn-server2[28944]: 141.226.***.254:5435 PLUGIN_CALL: POST /usr/lib/openvpn-plugin-auth-pam.so/PLUGIN_AUTH_USER_PASS_VERIFY status=0
