Subnet support on N66 WAN port?
SuperTeeJay
Hello folks,
I will be having Hyperoptic broadband installed shortly and plan to use my N66 with Merlin instead of the supplied router. Their FAQ says:
"If you are a 20 Mb, or a 100Mb customer your router needs to support /31 (255.255.255.254) subnet mask on its WAN port in order for the router to work with Hyperoptic."
https://www.hyperoptic.com/connecting-a-non-hyperoptic-router/
(The ISP uses fibre to the building and then CAT6 from their equipment to a port in the flat.)
Could someone explain how I could configure the router to work properly? Thanks.
I would say nothing to do here, just choose
under WAN "WAN Connection Type" = Automatic IP
and the DHCP of the provider will do the rest!
In case you get a fixed IP from the vendor you need to choose
under WAN "WAN Connection Type" = Static IP,
and enter the details as given from the provider under "WAN IP Setting"
- including the Subnet Mask and Gateway​
I do not get why they question about "needs to support /31 (255.255.255.254) subnet mask on its WAN port" as this is default stuff for every router... :rolleyes:
Maybe the right question is:
Does the router support manual setting of the WAN IP configuration (including Subnet Mask of 255.255.255.254, Fixed IP and Gateway)? :oops:
Yes, initially I was a bit confused about this. But there is actually a difference :eek:.
They appear to be alluding to RFC 3021 (Using 31-Bit Prefixes on IPv4 Point-to-Point Links). Normally the smallest subnet you can have is /30 (255.255.255.252) because of the 2 reserved addresses (network address and broadcast address). RFC 3021 allows a /31 prefix by doing away with the two reserved addresses.
http://showipprotocols.blogspot.co.uk/2014/11/rfc3021-slash-31-subnets-for-ipv4-p2p-wan.html
https://www.ietf.org/rfc/rfc3021.txt
FYI My router's WAN connection is on a /22 (255.255.252.0) network.
Thanks guys. It sounds like, initially, I should just plug it in and see if it works without messing with any settings.
