sudo: unknown user: root
zidler
[me@AC5300][/tmp/home/root]> opkg install sudo
[CODE][me@AC5300][/tmp/home/root]> sudo ls
sudo: unable to initialize policy plugin
What should I do?
Need sudo for other reasons. Thank you.
What should I do?
No sure why you need SUDO if you are already ROOT on your router - SUDO switches temporary to ROOT if you are NOT superuser... :rolleyes:
admin@RT-AC87U:/tmp/home/root# opkg list | grep sudo
sudo - 1.8.14p3-1 - Sudo (su "do") allows a system administrator to delegate authority to give certain users (or groups of users) the ability to run some (or all) commands as root or another user while providing an audit trail of the commands and their arguments.
As I mentioned, I need it for personal reasons. Got tons of bash scripts I copy between my servers, most of them contain sudo in aliases. I don't want to redact 20 files, just to make it work.
That makes no sense. :confused: Not having sudo on the router won't effect bash scripts running on other servers.
Or do you mean your bash scripts copy files between servers? In which case the error message suggests that you don't have a user called "root" which is normally true. The "root" user is normally called "admin" in asuswrt, but your output suggests you have called it "me".
and? how can I add root user to the sistem? Sudo wont work without it.
The router is designed to be a single-user machine. (Nearly) everything runs as the "root" account. That's why there is no useradd, userdel, usermod, groupadd, groupdel, etc.
or use sed.
sed 's/sudo //g' oldfile > newfile
The symlink of sudo to /bin/false seems much easier but I dunno enough to know if there would be potential problems.
C Script to notify unknown device connects to LAN ASUS Wi-Fi 3
