hi guys
i'll be moving to my new home soon which is CAT 6 wired.
I'll be subscribing to a 1GBPS fibre connection and I need advise on the best router to get for my setup.
I'll be running a wired ethernet connection for my devices such as my android PC, Xbox, BluRay player. These only support 100MBPS connections.
The wireless function will only be used by my smart devices such as my LG G3, Xperia Z Ultra and Ipad mini or Ipad 3.
As of now, I do not have any laptops yet. Even if i did, I would only require them for standard internet access. No bit torrenting or fast wifi needed for downloads.
As such, what router would you recommend?
I would prefer to get something that doesnt degrade my wired connection's speed. thats the priority. Wifi speed is secondary.
At the same time, i wouldnt want to get something that is too old. Perhaps a AC router.
