Hi all,
I am sure this has been asked many times before. I need some advice re-48 port gigabit switch.
What I have:
Thanks,
SSri
What I have:
- Virgin 200 mb business grade broadband. This is connected to Asus AC 68U through Virgin hub (used as a modem now).
- I have turned off the wifi in Asus
- 2 UAP AC pro - currently connected via powerline adapters.
- CAT 6 (in-wall) cables have been laid and terminated using a patch panel at the loft
- The Virgin Model and Router will stay at the living room but will be connected via one Cat6 and a few as spares.
- 48 ports gigabit switch to connect the router.
- I want to replace the router with Mikrotik routerboard or a Qotom Mini PC as PfSense FW + Router.
- About half a dozen + VLANs including VLANs for the Wifi
- I am not sure if I need stackable feature as a future proof.
- I do not need POE+ switches as I have just a couple of UAP AC pros. I want to save some £££ here.
- This is for a typical home and home office uses.
- US 48 port or ES 48 Lite. I am not impressed, given the large number of issues re-PSU especially UK, several DoAs and 1 year warranty. Price point and features are a huge plus.
- Netgear GS748T-500EUS or a 752 model. I read the GUI needs Abobe Air and can be sensitive to the version I run. I am not sure if this is a problem.
- HPE 1920 48G, HPE 2530 48G and HPE 2920 48G. I am aware the 1920 is price attractive but the 2530 and 2920 are way too expensive (£700 - £1000 at least.
- I considered Cisco SMB 200-300, these are more expensive than HPE 1920 48G. I am also aware that the community generally do not recommend going down the HPE 1800s and 1900s.
Thanks,
SSri
