vmirjamali
So I'm currently using powerline boxes which is netting me only 50mbps and I read about Moca 2.0 recently.
I want to know if anyone can tell me if this is possible for my place.
I have coax coming from outside the home powered by spectrum sitting inside an access box with 4 other coax lines, going to the living room and 3 other bedrooms.
The sb6183 cable modem is currently hooked up to the living room coax cable, and my wifi router/powerline connects from there.
Is there a way to get every room connected to moca ethernet somehow with this setup, so i can disable my powerline adapter setup? I don't use cable tv, just spectrum cable internet. I can't cut modify the walls so actual cat6/7e is out of the question at this time. If anyone has any detailed help it would be greatly appreciated.
I've been searching the internet for hours with no luck.
Thanks!
Thanks!
