Synology Docker ipv6
Make sure that IPv6 is enabled on the docker host, and then go into the shell and update the dockerd.json file to set ipv6 to true, setting the ipv6 fixed cidr range to something that is inside your ipv6 scope. Once that is done, kick docker, and Bob's your uncle.
Should work fine after that, as the dockerd.json file is persistent until changed again...
Google can show you the way - hint here is to check the synology forums, as this has been asked and answered.
