sfx2000
Part of the Furniture
Version: 1.3.1-9346 Update 9
(2024-03-12)
Important Note
The update will be available for selected regions within the following weeks, although the release time in each region may vary slightly.
Fixed Issues
- Fixed the issue where SRM might not be able to establish an IPv6 PPPoE connection in Romania.
- Fixed the issue where SRM might not be able to establish a connection with certain ISPs that require more response time.
- Enhanced the roaming compatibility of clients between mesh Wi-Fi systems.
- Fixed the issue where the web interface of SRM might not respond smoothly.
- Fixed multiple security vulnerabilities. (Synology-SA-24:03)
You can find it here...
RT6600ax, MR2200ac, RT2600ac, WRX560
Download Center | Synology Inc.
Discover technical information with whitepapers, user guides, and datasheets to learn more about Synology products. Download the latest software patches to enjoy the best technologies.
