Syslog from RT-AC87
VANT
Hi.
If anyone can, please paste here bootlog from Yours RT-AC87u (from start to full operate), and additional result command
wl -i eth1 revinfo
Ofcourse hide/delete personal info like mac/ip adress.
This is for check possible difference between this routers.
Many thanks for help.
Bootlog:
(Bootlog and some reboots then)
Jan 24 17:57:05 rc_service: ntp 525:notify_rc restart_upnp
Jan 24 17:57:05 rc_service: waitting "stop_upnp" via ip-up ...
Jan 24 17:57:05 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan6)!
Jan 24 17:57:05 wan: finish adding multi routes
Jan 24 17:57:05 dhcp client: bound 10.25.137.241 via 10.25.128.1 during 43200 seconds.
Jan 24 17:57:06 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Jan 24 17:57:06 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Jan 24 17:57:06 kernel: usb usb1: No SuperSpeed endpoint companion for config 1  interface 0 altsetting 0 ep 129: using minimum values
Jan 24 17:57:08 rc_service: ntp 525:notify_rc restart_diskmon
Jan 24 17:57:08 disk_monitor: Finish
Jan 24 17:57:08 WAN Connection: WAN was restored.
Jan 24 17:57:10 disk monitor: be idle
Jan 24 17:57:14 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan6)!
Jan 24 17:57:15 zcip client: configured 169.254.89.101
Jan 24 17:57:25 dnsmasq-dhcp[466]: Ignoring domain 2_S140Y29953292 for DHCP host name zyxel_DTT7105-0
Jan 24 17:57:31 qtn: bootcfg.tgz exists
Jan 24 17:57:38 crond[474]: time disparity of 254457 minutes detected
Jan 24 18:00:10 disk_monitor: Got SIGALRM...
Jan 24 23:00:10 disk_monitor: Got SIGALRM...
Jan 26 21:03:33 rc_service: httpd 472:notify_rc restart_net_and_phy
Jan 26 21:03:36 iTunes: daemon is stoped
Jan 26 21:03:36 FTP Server: daemon is stoped
Jan 26 21:03:36 Samba Server: smb daemon is stoped
Jan 26 21:03:36 kernel: gro disabled
Jan 26 21:03:36 pppd[538]: Connection terminated.
Jan 26 21:03:37 kernel: Interface ppp0 doesn't exist
Jan 26 21:03:38 watchdog: restart httpd
Jan 26 21:03:38 rc_service: watchdog 477:notify_rc start_httpd
Jan 26 21:03:38 rc_service: waitting "restart_net_and_phy" via  ...
Jan 26 21:03:40 wanduck exit: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan6)!
Jan 26 21:03:40 kernel: UFFP entry not found
Jan 26 21:03:40 kernel: Interface wifi0 doesn't exist
Jan 26 21:03:41 kernel: Hooks already unregistered
Jan 26 21:03:41 kernel: Interface br0 doesn't exist
Jan 26 21:03:42 kernel: wl_module_init: passivemode set to 0x0
Jan 26 21:03:42 kernel: wl_module_init: igs set to 0x1
Jan 26 21:03:42 kernel: wl_module_init: txworkq set to 0x0
Jan 26 21:03:42 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.105 (r485445)
Jan 26 21:03:43 stop_nat_rules: apply the redirect_rules!
Jan 26 21:03:43 dnsmasq[1602]: warning: interface ppp1* does not currently exist
Jan 26 21:03:43 wan: [wan0_hwaddr] == [MAC]
Jan 26 21:03:43 pppd[1610]: pppd 2.4.7 started by admin, uid 0
Jan 26 21:03:43 wan: [wan10_hwaddr] == [MAC]
Jan 26 21:03:43 pppd[1610]: Connected to MAC via interface vlan6
Jan 26 21:03:43 pppd[1610]: Connect: ppp0 <--> vlan6
Jan 26 21:03:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules_10_vlan2_vlan2)!
Jan 26 21:03:44 pppd[1610]: CHAP authentication succeeded
Jan 26 21:03:44 pppd[1610]: peer from calling number MAC authorized
Jan 26 21:03:44 pppd[1610]: local  IP address 193.153.54.108
Jan 26 21:03:44 pppd[1610]: remote IP address 192.168.144.1
Jan 26 21:03:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan6)!
Jan 26 21:03:44 wan: finish adding multi routes
Jan 26 21:03:44 wan: [wan11_hwaddr] == [MAC]
Jan 26 21:03:44 rc_service: ip-up 1636:notify_rc stop_upnp
Jan 26 21:03:44 rc_service: waitting "restart_net_and_phy" via  ...
Jan 26 21:03:45 wan: finish adding multi routes
Jan 26 21:03:45 dhcp client: bound 10.25.137.241 via 10.25.128.1 during 43200 seconds.
Jan 26 21:03:48 RT-AC87U: start httpd
Jan 26 21:03:48 kernel: gro enabled with interval 2
Jan 26 21:03:49 rc_service: skip the event: start_httpd.
Jan 26 21:03:49 Samba Server: daemon is started
Jan 26 21:03:50 qtn: bootcfg.tgz exists
Jan 26 21:03:50 rc_service: ip-up 1636:notify_rc start_upnp
Jan 26 21:03:50 rc_service: waitting "stop_upnp" via ip-up ...
Jan 26 21:03:55 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan6)!
Jan 26 21:03:56 zcip client: configured 169.254.89.101
Jan 26 21:03:58 WAN Connection: WAN was restored.
Jan 26 21:21:48 rc_service: httpd 1732:notify_rc restart_net_and_phy
Jan 26 21:21:51 FTP Server: daemon is stoped
Jan 26 21:21:51 Samba Server: smb daemon is stoped
Jan 26 21:21:51 kernel: gro disabled
Jan 26 21:21:52 pppd[1610]: Connection terminated.
Jan 26 21:21:53 kernel: Interface ppp0 doesn't exist
Jan 26 21:21:57 wanduck exit: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan6)!
Jan 26 21:21:58 kernel: Interface wifi0 doesn't exist
Jan 26 21:21:58 kernel: Hooks already unregistered
Jan 26 21:21:58 kernel: Interface br0 doesn't exist
Jan 26 21:22:00 kernel: wl_module_init: passivemode set to 0x0
Jan 26 21:22:00 kernel: wl_module_init: igs set to 0x1
Jan 26 21:22:00 kernel: wl_module_init: txworkq set to 0x0
Jan 26 21:22:00 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.105 (r485445)
Jan 26 21:22:00 stop_nat_rules: apply the redirect_rules!
Jan 26 21:22:00 dnsmasq[1932]: warning: interface ppp1* does not currently exist
Jan 26 21:22:00 wan: [wan0_hwaddr] == [MAC]
Jan 26 21:22:01 pppd[1940]: pppd 2.4.7 started by admin, uid 0
Jan 26 21:22:01 wan: [wan10_hwaddr] == [MAC]
Jan 26 21:22:01 pppd[1940]: Connected to MAC via interface vlan6
Jan 26 21:22:01 pppd[1940]: Connect: ppp0 <--> vlan6
Jan 26 21:22:01 start_nat_rules: apply the nat_rules(/tmp/nat_rules_10_vlan2_vlan2)!
Jan 26 21:22:01 pppd[1940]: CHAP authentication succeeded
Jan 26 21:22:01 pppd[1940]: peer from calling number MAC authorized
Jan 26 21:22:01 pppd[1940]: local  IP address 88.14.57.105
Jan 26 21:22:01 pppd[1940]: remote IP address 192.168.144.1
Jan 26 21:22:01 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan6)!
Jan 26 21:22:01 wan: finish adding multi routes
Jan 26 21:22:01 rc_service: ip-up 1962:notify_rc stop_upnp
Jan 26 21:22:01 rc_service: waitting "restart_net_and_phy" via  ...
Jan 26 21:22:05 WAN Connection: WAN was restored.
Jan 26 21:22:06 wan: [wan11_hwaddr] == [MAC]
Jan 26 21:22:07 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan6)!
Jan 26 21:22:07 wan: finish adding multi routes
Jan 26 21:22:07 dhcp client: bound 10.25.137.241 via 10.25.128.1 during 43200 seconds.
Jan 26 21:22:10 RT-AC87U: start httpd
Jan 26 21:22:10 kernel: gro enabled with interval 2
Jan 26 21:22:11 Samba Server: daemon is started
Jan 26 21:22:11 rc_service: ip-up 1962:notify_rc start_upnp
Jan 26 21:22:11 rc_service: waitting "stop_upnp" via ip-up ...
Jan 26 21:22:12 qtn: bootcfg.tgz exists
Jan 26 21:22:14 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan6)!
Jan 26 21:22:16 zcip client: configured 169.254.89.101
Jan 26 22:14:45 rc_service: httpd 2063:notify_rc restart_net_and_phy
Jan 26 22:14:48 iTunes: daemon is stoped
Jan 26 22:14:48 FTP Server: daemon is stoped
Jan 26 22:14:49 Samba Server: smb daemon is stoped
Jan 26 22:14:49 kernel: gro disabled
Jan 26 22:14:49 pppd[1940]: Connection terminated.
Jan 26 22:14:50 kernel: Interface ppp0 doesn't exist
Jan 26 22:14:55 wanduck exit: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan6)!
Jan 26 22:14:55 kernel: Interface wifi0 doesn't exist
Jan 26 22:14:55 kernel: Hooks already unregistered
Jan 26 22:14:55 kernel: Interface br0 doesn't exist
Jan 26 22:14:56 kernel: Interface br0 doesn't exist
Jan 26 22:14:57 kernel: wl_module_init: passivemode set to 0x0
Jan 26 22:14:57 kernel: wl_module_init: igs set to 0x1
Jan 26 22:14:57 kernel: wl_module_init: txworkq set to 0x0
Jan 26 22:14:57 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.105 (r485445)
Jan 26 22:14:58 stop_nat_rules: apply the redirect_rules!
Jan 26 22:14:58 dnsmasq[2261]: warning: interface ppp1* does not currently exist
Jan 26 22:14:58 wan: [wan0_hwaddr] == [MAC]
Jan 26 22:14:58 pppd[2269]: pppd 2.4.7 started by admin, uid 0
Jan 26 22:14:58 wan: [wan10_hwaddr] == [MAC]
Jan 26 22:14:58 pppd[2269]: Connected to MAC via interface vlan6
Jan 26 22:14:58 pppd[2269]: Connect: ppp0 <--> vlan6
Jan 26 22:14:58 pppd[2269]: CHAP authentication succeeded
Jan 26 22:14:58 pppd[2269]: peer from calling number MAC authorized
Jan 26 22:14:58 start_nat_rules: apply the nat_rules(/tmp/nat_rules_10_vlan2_vlan2)!
Jan 26 22:14:58 pppd[2269]: local  IP address 176.86.96.155
Jan 26 22:14:58 pppd[2269]: remote IP address 192.168.144.1
Jan 26 22:14:59 start_nat_rules: apply the nat_rules(/tmp/nat_rules_0_ppp0_vlan6)!
Jan 26 22:14:59 wan: finish adding multi routes
Jan 26 22:14:59 wan: [wan11_hwaddr] == [MAC]
Jan 26 22:14:59 dhcp client: bound 10.25.137.241 via 10.25.128.1 during 43200 seconds.
Jan 26 22:15:02 RT-AC87U: start httpd
Jan 26 22:15:02 kernel: gro enabled with interval 2
Jan 26 22:15:03 WAN Connection: WAN was restored.
Jan 26 22:15:03 Samba Server: daemon is started
Jan 26 22:15:04 rc_service: ip-up 2285:notify_rc stop_upnp
Jan 26 22:15:04 rc_service: ip-up 2285:notify_rc start_upnp
Jan 26 22:15:04 rc_service: waitting "stop_upnp" via ip-up ...
Command:
vendorid 0x14e4
deviceid 0x43a1
radiorev 0x42069000
chipnum 0x4360
chiprev 0x3
chippackage 0x1
corerev 0x2a
boardid 0x665
boardvendor 0x14e4
boardrev P103
driverrev 0x6250e69
ucoderev 0x38b0075
bus 0x1
phytype 0xb
phyrev 0x1
anarev 0x0
nvramrev 0
thx for log, but if You can paste bootlog with hardware info, partition in nand etc (first data after boot/reboot.
no one want help ?
no one want help ?
Always happy to help... :rolleyes:
Here part 1 with the initial log details:
Aug  1 02:00:13 syslogd started: BusyBox v1.20.2
Aug  1 02:00:13 kernel: klogd started: BusyBox v1.20.2 (2016-02-17 05:10:04 WET)
Aug  1 02:00:13 kernel: Linux version 2.6.36.4brcmarm (root@backbone) (gcc version 4.5.3 (Buildroot 2012.02) ) #458 SMP PREEMPT Wed Feb 17 05:19:36 WET 2016
Aug  1 02:00:13 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Aug  1 02:00:13 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug  1 02:00:13 kernel: Machine: Northstar Prototype
Aug  1 02:00:13 kernel: Ignoring unrecognised tag 0x00000000
Aug  1 02:00:13 kernel: bootconsole [earlycon0] enabled
Aug  1 02:00:13 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug  1 02:00:13 kernel: MPCORE found at 19020000
Aug  1 02:00:13 kernel: PERCPU: Embedded 7 pages/cpu @c8215000 s5472 r8192 d15008 u65536
Aug  1 02:00:13 kernel: pcpu-alloc: s5472 r8192 d15008 u65536 alloc=16*4096
Aug  1 02:00:13 kernel: pcpu-alloc: [0] 0 [0] 1
Aug  1 02:00:13 kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60416
Aug  1 02:00:13 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug  1 02:00:13 kernel: PID hash table entries: 1024 (order: 0, 4096 bytes)
Aug  1 02:00:13 kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Aug  1 02:00:13 kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Aug  1 02:00:13 kernel: Memory: 128MB 128MB = 256MB total
Aug  1 02:00:13 kernel: Memory: 254952k/254952k available, 7192k reserved, 0K highmem
Aug  1 02:00:13 kernel: Virtual kernel memory layout:
Aug  1 02:00:13 kernel:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Aug  1 02:00:13 kernel:     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
Aug  1 02:00:13 kernel:     DMA     : 0xf7e00000 - 0xffe00000   ( 128 MB)
Aug  1 02:00:13 kernel:     vmalloc : 0xd0800000 - 0xf0000000   ( 504 MB)
Aug  1 02:00:13 kernel:     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
Aug  1 02:00:13 kernel:     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Aug  1 02:00:13 kernel:       .init : 0xc0008000 - 0xc003e000   ( 216 kB)
Aug  1 02:00:13 kernel:       .text : 0xc003e000 - 0xc042f000   (4036 kB)
Aug  1 02:00:13 kernel:       .data : 0xc0446000 - 0xc0469500   ( 142 kB)
Aug  1 02:00:13 kernel: SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Aug  1 02:00:13 kernel: Hierarchical RCU implementation.
Aug  1 02:00:13 kernel:     RCU-based detection of stalled CPUs is disabled.
Aug  1 02:00:13 kernel:     Verbose stalled-CPUs detection is disabled.
Aug  1 02:00:13 kernel: NR_IRQS:256
Aug  1 02:00:13 kernel: MPCORE GIC init
Aug  1 02:00:13 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06 ignored.
Aug  1 02:00:13 kernel: MPCORE Global Timer Clock 600000000Hz
Aug  1 02:00:13 kernel: Calibrating delay loop... 2398.61 BogoMIPS (lpj=11993088)
Aug  1 02:00:13 kernel: pid_max: default: 32768 minimum: 301
Aug  1 02:00:13 kernel: Mount-cache hash table entries: 512
Aug  1 02:00:13 kernel: CPU: Testing write buffer coherency: ok
Aug  1 02:00:13 kernel: MPCORE Private timer setup CPU0
Aug  1 02:00:13 kernel: Calibrating local timer... 599.814MHz.
Aug  1 02:00:13 kernel: L310: cache controller enabled 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x7a130000
Aug  1 02:00:13 kernel: CPU1: Booted secondary processor
Aug  1 02:00:13 kernel: MPCORE Private timer setup CPU1
Aug  1 02:00:13 kernel: Brought up 2 CPUs
Aug  1 02:00:13 kernel: SMP: Total of 2 processors activated (4797.23 BogoMIPS).
Aug  1 02:00:13 kernel: devtmpfs: initialized
Aug  1 02:00:13 kernel: atomic64 test passed
Aug  1 02:00:13 kernel: NET: Registered protocol family 16
Aug  1 02:00:13 kernel: Found a AMD NAND flash:
Aug  1 02:00:13 kernel: Total size:  128MB
Aug  1 02:00:13 kernel: Block size:  128KB
Aug  1 02:00:13 kernel: Page Size:   2048B
Aug  1 02:00:13 kernel: OOB Size:    64B
Aug  1 02:00:13 kernel: Sector size: 512B
Aug  1 02:00:13 kernel: Spare size:  16B
Aug  1 02:00:13 kernel: ECC level:   8 (8-bit)
Aug  1 02:00:14 kernel: Device ID: 0x 1 0xf1 0x80 0x1d 0x 1 0xf1
Aug  1 02:00:14 kernel: CCA UART Clock Config: Sel=1 Ovr=1 Div=48
Aug  1 02:00:14 kernel: CCA UART Clock rate 125000000Hz
Aug  1 02:00:14 kernel: bio: create slab <bio-0> at 0
Aug  1 02:00:14 kernel: Switching to clocksource mpcore_gtimer
Aug  1 02:00:14 kernel: NET: Registered protocol family 2
Aug  1 02:00:14 kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Aug  1 02:00:14 kernel: TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Aug  1 02:00:14 kernel: TCP bind hash table entries: 8192 (order: 4, 98304 bytes)
Aug  1 02:00:14 kernel: TCP: Hash tables configured (established 8192 bind 8192)
Aug  1 02:00:14 kernel: TCP reno registered
Aug  1 02:00:14 kernel: UDP hash table entries: 128 (order: 0, 4096 bytes)
Aug  1 02:00:14 kernel: UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
Aug  1 02:00:14 kernel: NET: Registered protocol family 1
Aug  1 02:00:14 kernel: PCI: no core
Aug  1 02:00:14 kernel: PCI: scanning bus 0
Aug  1 02:00:14 kernel: PCI: Fixing up bus 0
Aug  1 02:00:14 kernel: PCIE1 link=1
Aug  1 02:00:14 kernel: PCIE1 switching to GEN2
Aug  1 02:00:14 kernel: PCI: bus0: Fast back to back transfers disabled
Aug  1 02:00:14 kernel: PCI: Fixing up bus 1
Aug  1 02:00:14 kernel: PCI: bus1: Fast back to back transfers disabled
Aug  1 02:00:14 kernel: pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
Aug  1 02:00:14 kernel: pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
Aug  1 02:00:14 kernel: pci 0001:01:00.0: BAR 0: set to [mem 0x08000000-0x08007fff 64bit] (PCI address [0x8000000-0x8007fff]
Aug  1 02:00:14 kernel: pci 0001:00:00.0: PCI bridge to [bus 01-01]
Aug  1 02:00:14 kernel: pci 0001:00:00.0:   bridge window [io  disabled]
Aug  1 02:00:14 kernel: pci 0001:00:00.0:   bridge window [mem 0x08000000-0x080fffff]
Aug  1 02:00:14 kernel: pci 0001:00:00.0:   bridge window [mem pref disabled]
Aug  1 02:00:14 kernel: PCIE2 link=0
Aug  1 02:00:14 kernel: PCIE3 link=0
Aug  1 02:00:14 kernel: VFS: Disk quotas dquot_6.5.2
Aug  1 02:00:14 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug  1 02:00:14 kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Aug  1 02:00:14 kernel: fuse init (API version 7.15)
Aug  1 02:00:14 kernel: msgmni has been set to 497
Aug  1 02:00:14 kernel: io scheduler noop registered (default)
Aug  1 02:00:14 kernel: io scheduler deadline registered
Aug  1 02:00:14 kernel: io scheduler cfq registered
Aug  1 02:00:14 kernel: Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
Aug  1 02:00:14 kernel: serial8250.0: ttyS0 at MMIO 0x18000300 (irq = 117) is a 16550
Aug  1 02:00:14 kernel: console [ttyS0] enabled, bootconsole disabled
Aug  1 02:00:14 kernel: serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550
Aug  1 02:00:14 kernel: brd: module loaded
Aug  1 02:00:14 kernel: loop: module loaded
Aug  1 02:00:14 kernel: pflash: found no supported devices
Aug  1 02:00:14 kernel: bcmsflash: found no supported devices
Aug  1 02:00:14 kernel: Boot partition size = 524288(0x80000)
Aug  1 02:00:14 kernel: lookup_nflash_rootfs_offset: offset = 0x200000
Aug  1 02:00:14 kernel: nflash: squash filesystem with lzma found at block 30
Aug  1 02:00:14 kernel: Creating 4 MTD partitions on "nflash":
Aug  1 02:00:14 kernel: 0x000000000000-0x000000080000 : "boot"
Aug  1 02:00:14 kernel: 0x000000080000-0x000000200000 : "nvram"
Aug  1 02:00:14 kernel: 0x000000200000-0x000004000000 : "linux"
Aug  1 02:00:14 kernel: 0x0000003c785c-0x000004000000 : "rootfs"
Aug  1 02:00:14 kernel: PPP generic driver version 2.4.2
Aug  1 02:00:14 kernel: PPP MPPE Compression module registered
Aug  1 02:00:14 kernel: NET: Registered protocol family 24
Aug  1 02:00:14 kernel: PPTP driver version 0.8.5
Aug  1 02:00:14 kernel: u32 classifier
Aug  1 02:00:14 kernel:     Actions configured
Aug  1 02:00:14 kernel: Netfilter messages via NETLINK v0.30.
Aug  1 02:00:14 kernel: nf_conntrack version 0.5.0 (3983 buckets, 15932 max)
Aug  1 02:00:14 kernel: xt_time: kernel timezone is -0000
Aug  1 02:00:14 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Aug  1 02:00:14 kernel: TCP bic registered
Aug  1 02:00:14 kernel: TCP cubic registered
Aug  1 02:00:14 kernel: TCP westwood registered
Aug  1 02:00:14 kernel: TCP highspeed registered
Aug  1 02:00:14 kernel: TCP hybla registered
Aug  1 02:00:14 kernel: TCP htcp registered
Aug  1 02:00:14 kernel: TCP vegas registered
Aug  1 02:00:14 kernel: TCP veno registered
Aug  1 02:00:14 kernel: TCP scalable registered
Aug  1 02:00:14 kernel: TCP lp registered
Aug  1 02:00:14 kernel: TCP yeah registered
Aug  1 02:00:14 kernel: TCP illinois registered
Aug  1 02:00:14 kernel: NET: Registered protocol family 10
Aug  1 02:00:14 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Aug  1 02:00:14 kernel: NET: Registered protocol family 17
Aug  1 02:00:14 kernel: L2TP core driver, V2.0
Aug  1 02:00:14 kernel: PPPoL2TP kernel driver, V2.0
Aug  1 02:00:14 kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Aug  1 02:00:14 kernel: All bugs added by David S. Miller <davem@redhat.com>
Aug  1 02:00:14 kernel: Registering the dns_resolver key type
Aug  1 02:00:14 kernel: Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012
Aug  1 02:00:14 kernel: NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)
Full log is 34k in my case (even if I removed some confidential parts) - cannot be posted here as the limit is 10.000 characters.
And now part 2:
Aug  1 02:00:14 kernel: Spare area=64 eccbytes 56, ecc bytes located at:
Aug  1 02:00:14 kernel:  2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Aug  1 02:00:14 kernel: Available 7 bytes at (off,len):
Aug  1 02:00:14 kernel: (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Aug  1 02:00:14 kernel: Scanning device for bad blocks
Aug  1 02:00:14 kernel: Options: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,
Aug  1 02:00:14 kernel: Creating 2 MTD partitions on "brcmnand":
Aug  1 02:00:14 kernel: 0x000004000000-0x000007ec0000 : "brcmnand"
Aug  1 02:00:14 kernel: 0x000007ec0000-0x000008000000 : "asus"
Aug  1 02:00:14 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Aug  1 02:00:14 kernel: devtmpfs: mounted
Aug  1 02:00:14 kernel: Freeing init memory: 216K
Aug  1 02:00:14 kernel: ctf: module license 'Proprietary' taints kernel.
Aug  1 02:00:14 kernel: Disabling lock debugging due to kernel taint
Aug  1 02:00:14 kernel: et_module_init: passivemode set to 0x0
Aug  1 02:00:14 kernel: et_module_init: txworkq set to 0x1
Aug  1 02:00:14 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug  1 02:00:14 kernel: =================
Aug  1 02:00:14 kernel: robo chk regs:
Aug  1 02:00:14 kernel: ===================
Aug  1 02:00:14 kernel: (0x00,0x5d)Port 5 States Override: 0xfb
Aug  1 02:00:14 kernel: (0x00,0x5f)Port 7 States Override: 0xfb
Aug  1 02:00:15 STOP_init-start: return code 0
Aug  1 02:00:15 kernel: (0x00,0x0e)Port 8 States Override: 0x0a
Aug  1 02:00:15 kernel: (0x00,0x08)Port 8 IMP Control Register: 0x00
Aug  1 02:00:15 kernel: (0x02,0x00) Global Management Config: 0x00
Aug  1 02:00:15 kernel: (0x02,0x00) 802.1Q VLAN Control 5: 0x00
Aug  1 02:00:15 kernel: (0x02,0x03) BRCM HDR Control Register: 0x00
Aug  1 02:00:15 kernel: (0x00,0x0b) Switch Mode Register: 0x06
Aug  1 02:00:15 kernel: aux0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.126 (r561982)
Aug  1 02:00:15 kernel: =================
Aug  1 02:00:15 kernel: robo chk regs:
Aug  1 02:00:15 kernel: ===================
Aug  1 02:00:15 kernel: (0x00,0x5d)Port 5 States Override: 0xfb
Aug  1 02:00:15 kernel: (0x00,0x5f)Port 7 States Override: 0xfb
Aug  1 02:00:15 kernel: (0x00,0x0e)Port 8 States Override: 0xfb
Aug  1 02:00:15 kernel: (0x00,0x08)Port 8 IMP Control Register: 0x1c
Aug  1 02:00:15 kernel: (0x02,0x00) Global Management Config: 0x80
Aug  1 02:00:15 kernel: (0x02,0x00) 802.1Q VLAN Control 5: 0x80
Aug  1 02:00:15 kernel: (0x00,0x0b) Switch Mode Register: 0x07
Aug  1 02:00:15 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.126 (r561982)
Aug  1 02:00:15 kernel: wl_module_init: passivemode set to 0x0
Aug  1 02:00:15 kernel: wl_module_init: igs set to 0x0
Aug  1 02:00:15 kernel: wl_module_init: txworkq set to 0x1
Aug  1 02:00:15 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.105 (r485445)
Aug  1 02:00:15 kernel: JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Aug  1 02:00:15 kernel: device vlan1 entered promiscuous mode
Aug  1 02:00:15 kernel: device eth0 entered promiscuous mode
Aug  1 02:00:16 kernel: device eth1 entered promiscuous mode
Aug  1 02:00:16 kernel: device wl0.3 entered promiscuous mode
Aug  1 02:00:16 kernel: br0: port 3(wl0.3) entering forwarding state
Aug  1 02:00:16 kernel: br0: port 2(eth1) entering forwarding state
Aug  1 02:00:16 kernel: br0: port 1(vlan1) entering forwarding state
Aug  1 02:00:16 stop_nat_rules: apply the redirect_rules!
Aug  1 02:00:16 qcsapi: write qcsapi conf ok
Aug  1 02:00:16 WAN Connection: ISP's DHCP did not function properly.
Aug  1 02:00:26 custom config: Appending content of /jffs/configs/hosts.add.
Aug  1 02:00:26 custom config: Appending content of /jffs/configs/dnsmasq.conf.add.
Aug  1 02:00:26 dnsmasq[784]: started, version 2.76-g41a8d9e cachesize 1500
Aug  1 02:00:26 dnsmasq[784]: warning: interface ppp1* does not currently exist
Aug  1 02:00:26 dnsmasq[784]: warning: ignoring resolv-file flag because no-resolv is set
Aug  1 02:00:26 dnsmasq[784]: asynchronous logging enabled, queue limit is 5 messages
Aug  1 02:00:26 dnsmasq-dhcp[784]: DHCP, IP range xxx.xxx.xxx.xxx -- xxx.xxx.xxx.xxx, lease time 1d
Aug  1 02:00:26 dnsmasq[784]: using nameserver 127.0.0.1#65053
Aug  1 02:00:26 dnsmasq[784]: using local addresses only for domain DREAM
Aug  1 02:00:26 dnsmasq[784]: read /etc/hosts - 30 addresses
Aug  1 02:00:26 dnsmasq[784]: read /etc/hosts.dnsmasq - 23 addresses
Aug  1 02:00:26 dnsmasq-dhcp[784]: read /etc/ethers - 23 addresses
Aug  1 02:00:26 httpd: start httpd
Aug  1 02:00:26 crond[792]: crond: crond (busybox 1.20.2) started, log level 8
Aug  1 02:00:27 kernel: gro enabled with interval 2
Aug  1 02:00:27 disk monitor: be idle
Aug  1 02:00:27 hour monitor: daemon is starting
Aug  1 02:00:27 hour monitor: ntp is not syn
Aug  1 02:00:27 custom config: Using custom /jffs/configs/smb.conf config file.
Aug  1 02:00:28 Samba Server: daemon is started
Aug  1 02:00:29 custom script: Running /jffs/scripts/services-start
Aug  1 02:00:29 START_services-start: started []
Aug  1 02:00:29 kernel: Ebtables v2.0 registered
Aug  1 02:00:29 wan: [wan0_hwaddr] == [XX:XX:XX:XX:XX:XX]
Aug  1 02:00:29 dnsmasq[784]: read /etc/hosts - 30 addresses
Aug  1 02:00:29 dnsmasq[784]: read /etc/hosts.dnsmasq - 23 addresses
Aug  1 02:00:29 dnsmasq-dhcp[784]: read /etc/ethers - 23 addresses
Aug  1 02:00:29 dnsmasq[784]: using nameserver 127.0.0.1#65053
Aug  1 02:00:29 dnsmasq[784]: using local addresses only for domain DREAM
Aug  1 02:00:29 STOP_services-start: return code 0
Aug  1 02:00:29 kernel: usbcore: registered new interface driver usbfs
Aug  1 02:00:29 kernel: usbcore: registered new interface driver hub
Aug  1 02:00:29 kernel: usbcore: registered new device driver usb
Aug  1 02:00:29 kernel: SCSI subsystem initialized
Aug  1 02:00:30 custom script: Running /jffs/scripts/wan-start (args: 0)
Aug  1 02:00:30 rc_service: udhcpc 1003:notify_rc start_firewall
Aug  1 02:00:30 dnsmasq[784]: read /etc/hosts - 30 addresses
Aug  1 02:00:30 dnsmasq[784]: read /etc/hosts.dnsmasq - 23 addresses
Aug  1 02:00:30 dnsmasq-dhcp[784]: read /etc/ethers - 23 addresses
Aug  1 02:00:30 dnsmasq[784]: using nameserver 127.0.0.1#65053
Aug  1 02:00:30 dnsmasq[784]: using local addresses only for domain DREAM
Aug  1 02:00:30 START_wan-start: started [0]
Aug  1 02:00:30 kernel: csw_retry 100
Aug  1 02:00:30 kernel: Initializing USB Mass Storage driver...
Aug  1 02:00:30 kernel: usbcore: registered new interface driver usb-storage
Aug  1 02:00:30 kernel: USB Mass Storage support registered.
Aug  1 02:00:30 STOP_wan-start: return code 0
Aug  1 02:00:30 wan: finish adding multi routes
Aug  1 02:00:30 kernel: Tuxera FAT 12/16/32 driver version 3015.1.29.1 [Flags: R/W MODULE].
Aug  1 02:00:30 kernel: Built against headers 2.6.36.4brcmarm #1 SMP PREEMPT Fri Jul 31 10:54:55 CST 2015 arm
Aug  1 02:00:30 kernel: Running on kernel 2.6.36.4brcmarm #458 SMP PREEMPT Wed Feb 17 05:19:36 WET 2016 armv7l
Aug  1 02:00:30 kernel: Tuxera NTFS driver 3015.1.29.1 [Flags: R/W MODULE].
Aug  1 02:00:30 kernel: Tuxera HFS+ driver 3014.7.28
Aug  1 02:00:30 kernel: xhci_hcd 0000:00:0c.0: xHCI Host Controller
Aug  1 02:00:30 kernel: xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 1
Aug  1 02:00:30 kernel: xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000
Aug  1 02:00:30 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Aug  1 02:00:30 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Aug  1 02:00:30 kernel: usb usb1: No SuperSpeed endpoint companion for config 1  interface 0 altsetting 0 ep 129: using minimum values
Aug  1 02:00:31 kernel: hub 1-0:1.0: USB hub found
Aug  1 02:00:31 kernel: hub 1-0:1.0: 1 port detected
Aug  1 02:00:31 kernel: [xhci-hub] usb2mode:[0]
Aug  1 02:00:31 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug  1 02:00:31 kernel: ehci_hcd 0000:00:0b.1: EHCI Host Controller
Aug  1 02:00:31 kernel: ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 2
Aug  1 02:00:31 kernel: ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000
Aug  1 02:00:31 kernel: ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00
Aug  1 02:00:31 kernel: hub 2-0:1.0: USB hub found
Aug  1 02:00:31 kernel: hub 2-0:1.0: 2 ports detected
Aug  1 02:00:31 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Aug  1 02:00:31 kernel: ohci_hcd 0000:00:0b.0: OHCI Host Controller
Aug  1 02:00:31 kernel: ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 3
Aug  1 02:00:31 kernel: ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000
Aug  1 02:00:31 kernel: hub 3-0:1.0: USB hub found
And now (guess what?) part 3:
Aug  1 02:00:31 kernel: hub 3-0:1.0: 2 ports detected
Aug  1 02:00:31 kernel: usb 1-1: new SuperSpeed USB device using xhci_hcd and address 2
Aug  1 02:00:31 kernel: usbcore: registered new interface driver usblp
Aug  1 02:00:31 kernel: xhci_hcd 0000:00:0c.0: WARN: short transfer on control ep
Aug  1 02:00:31 kernel: xhci_hcd 0000:00:0c.0: disable burst on ep 1
Aug  1 02:00:31 kernel: xhci_hcd 0000:00:0c.0: WARN no SS endpoint bMaxBurst
Aug  1 02:00:31 kernel: xhci_hcd 0000:00:0c.0: disable burst on ep 2
Aug  1 02:00:31 kernel: scsi0 : usb-storage 1-1:1.0
Aug  1 02:00:31 kernel: usbcore: registered new interface driver asix
Aug  1 02:00:31 kernel: usbcore: registered new interface driver cdc_ether
Aug  1 02:00:31 kernel: usbcore: registered new interface driver rndis_host
Aug  1 02:00:31 kernel: cdc_ncm: 14-Mar-2012
Aug  1 02:00:31 kernel: usbcore: registered new interface driver cdc_ncm
Aug  1 02:00:31 kernel: usbcore: registered new interface driver cdc_wdm
Aug  1 02:00:31 kernel: usb 2-2: new high speed USB device using ehci_hcd and address 2
Aug  1 02:00:31 kernel: usbcore: registered new interface driver qmi_wwan
Aug  1 02:00:31 kernel: cdc_mbim: loaded
Aug  1 02:00:31 kernel: usbcore: registered new interface driver cdc_mbim
Aug  1 02:00:31 kernel: scsi1 : usb-storage 2-2:1.0
Aug  1 02:00:32 WAN Connection: WAN was restored.
Aug  1 02:00:32 start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
Aug  1 02:00:32 kernel: scsi 0:0:0:0: Direct-Access     WD       Elements 1048    1022 PQ: 0 ANSI: 6
Aug  1 02:00:32 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Aug  1 02:00:32 kernel: sd 0:0:0:0: [sda] 1953519616 512-byte logical blocks: (1.00 TB/931 GiB)
Aug  1 02:00:32 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Aug  1 02:00:32 kernel: sd 0:0:0:0: [sda] Write Protect is off
Aug  1 02:00:32 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Aug  1 02:00:32 start_nat_rules: apply the nat_rules(/tmp/nat_rules_vlan2_vlan2)!
Aug  1 02:00:32 custom script: Running /jffs/scripts/nat-start
Aug  1 02:00:32 kernel: scsi 1:0:0:0: Direct-Access     SanDisk  Cruzer Fit       1.26 PQ: 0 ANSI: 5
Aug  1 02:00:32 kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Aug  1 02:00:32 kernel: sd 1:0:0:0: [sdb] 15633408 512-byte logical blocks: (8.00 GB/7.45 GiB)
Aug  1 02:00:32 kernel: sd 1:0:0:0: [sdb] Write Protect is off
Aug  1 02:00:32 kernel: sd 1:0:0:0: [sdb] Assuming drive cache: write through
Aug  1 02:00:32 kernel:  sdb: sdb1 sdb2
Aug  1 02:00:32 kernel: sd 1:0:0:0: [sdb] Attached SCSI removable disk
Aug  1 02:00:32 kernel:  sda: sda1 sda2
Aug  1 02:00:32 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Aug  1 02:00:33 START_nat-start: started []
Aug  1 02:00:33 custom script: Running /jffs/scripts/nat-start
Aug  1 02:00:33 STOP_nat-start: return code 0
Aug  1 02:00:33 custom script: Running /jffs/scripts/pre-mount (args: /dev/sda1)
Aug  1 02:00:33 START_pre-mount: started [/dev/sda1]
Aug  1 02:00:33 STOP_pre-mount: return code 0
Aug  1 02:00:33 custom script: Running /jffs/scripts/pre-mount (args: /dev/sdb1)
Aug  1 02:00:33 START_pre-mount: started [/dev/sdb1]
Aug  1 02:00:33 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 02:00:33 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 02:00:33 kernel: Adding 262140k swap on /dev/sdb1.  Priority:-1 extents:1 across:262140k
Aug  1 02:00:33 custom script: Running /jffs/scripts/pre-mount (args: /dev/sdb2)
Aug  1 02:00:33 custom script: Running /jffs/scripts/firewall-start (args: vlan2)
Aug  1 02:00:33 START_pre-mount: started [/dev/sdb2]
Aug  1 02:00:34 START_firewall-start: started [vlan2]
Aug  1 02:00:34 STOP_pre-mount: return code 0
Aug  1 02:00:34 STOP_firewall-start: return code 0
Aug  1 02:00:35 kernel: EXT3-fs: barriers not enabled
Aug  1 02:00:35 kernel: kjournald starting.  Commit interval 5 seconds
Aug  1 02:00:35 syslog: USB ext3 fs at /dev/sdb2 mounted on /tmp/mnt/ac87u
Aug  1 02:00:35 usb: USB ext3 fs at /dev/sdb2 mounted on /tmp/mnt/ac87u.
Aug  1 02:00:35 kernel: EXT3-fs (sdb2): using internal journal
Aug  1 02:00:35 kernel: EXT3-fs (sdb2): mounted filesystem with ordered data mode
Aug  1 02:00:35 custom script: Running /jffs/scripts/post-mount (args: /tmp/mnt/ac87u)
Aug  1 02:00:35 START_post-mount: started [/tmp/mnt/ac87u]
Aug  1 02:00:35 STOP_post-mount: return code 0
Aug  1 02:00:35 rc_service: hotplug 1260:notify_rc restart_nasapps
Aug  1 02:00:35 FTP Server: daemon is stopped
Aug  1 02:00:36 Samba Server: smb daemon is stopped
Aug  1 02:00:36 kernel: gro disabled
Aug  1 02:00:36 Timemachine: daemon is stopped
Aug  1 02:00:36 kernel: gro enabled with interval 2
Aug  1 02:00:36 custom config: Using custom /jffs/configs/smb.conf config file.
Aug  1 02:00:37 Samba Server: daemon is started
Aug  1 02:00:37 custom script: Running /jffs/scripts/pre-mount (args: /dev/sda2)
Aug  1 02:00:38 START_pre-mount: started [/dev/sda2]
Aug  1 02:00:38 STOP_pre-mount: return code 0
Aug  1 02:00:38 syslog: USB ext4 fs at /dev/sda2 mounted on /tmp/mnt/Data
Aug  1 02:00:38 usb: USB ext4 fs at /dev/sda2 mounted on /tmp/mnt/Data.
Aug  1 02:00:38 kernel: EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: user_xattr
Aug  1 02:00:38 custom script: Running /jffs/scripts/post-mount (args: /tmp/mnt/Data)
Aug  1 02:00:38 START_post-mount: started [/tmp/mnt/Data]
Aug  1 02:00:39 rc_service: service 1519:notify_rc restart_ntpc
Aug  1 02:00:40 rc_service: service 1523:notify_rc restart_httpd
Aug  1 02:00:40 httpd: start httpd
Aug  1 02:00:42 admin: Started  from .
Aug  1 02:00:42 dnscrypt-proxy: - [xxx] does not support DNS Security Extensions
Aug  1 02:00:42 dnscrypt-proxy: - [xxx] does not support Namecoin domains
Aug  1 02:00:42 dnscrypt-proxy[1549]: Starting dnscrypt-proxy 1.6.0
Aug  1 02:00:42 dnscrypt-proxy[1549]: Generating a new session key pair
Aug  1 02:00:42 dnscrypt-proxy[1549]: Done
Aug  1 02:00:42 dnscrypt-proxy[1549]: Server certificate #1435874751 received
Aug  1 02:00:42 dnscrypt-proxy[1549]: This certificate looks valid
Aug  1 02:00:42 START_S77ntpd-custom: started [start]
Aug  1 02:00:45 rc_service: udhcpc 1003:notify_rc stop_upnp
Aug  1 02:00:45 rc_service: udhcpc 1003:notify_rc start_upnp
Aug  1 02:00:45 rc_service: waitting "stop_upnp" via udhcpc ...
Aug  1 02:00:46 ntp: start NTP update
Aug  1 02:00:46 miniupnpd[1569]: HTTP listening on port 43071
Aug  1 02:00:46 miniupnpd[1569]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 23 23:41:17 rc_service: ntp 1520:notify_rc restart_upnp
Feb 23 23:41:17 miniupnpd[1569]: shutting down MiniUPnPd
Feb 23 23:41:18 miniupnpd[1579]: HTTP listening on port 37768
Feb 23 23:41:18 miniupnpd[1579]: Listening for NAT-PMP/PCP traffic on port 5351
Feb 23 23:41:18 openvpn-routing: Refreshing policy rules for client 1
Feb 23 23:41:18 openvpn-routing: Creating VPN routing table
Feb 23 23:41:18 openvpn-routing: Tunnel down - VPN client access blocked
Feb 23 23:41:18 rc_service: ntp 1520:notify_rc restart_diskmon
Feb 23 23:41:18 disk_monitor: Finish
Feb 23 23:41:19 openvpn-routing: Refreshing policy rules for client 2
Feb 23 23:41:20 openvpn-routing: Allow WAN access to all VPN clients
Feb 23 23:41:20 openvpn-routing: Refreshing policy rules for client 3
Feb 23 23:41:20 openvpn-routing: Refreshing policy rules for client 4
Feb 23 23:41:20 disk monitor: be idle
Feb 23 23:41:20 openvpn-routing: Refreshing policy rules for client 5
Feb 23 23:41:20 rc_service: udhcpc 1003:notify_rc start_vpnclient1
Feb 23 23:41:20 dhcp client: bound xxx.xxx.xxx.xxx via xxx.xxx.xxx.xxx during 300 seconds.
And now (ta, ta, taaaa!) the final part:
Feb 23 23:41:21 kernel: tun: Universal TUN/TAP device driver, 1.6
Feb 23 23:41:21 kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Feb 23 23:41:22 openvpn[1702]: OpenVPN 2.3.10 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Feb 17 2016
Feb 23 23:41:22 openvpn[1702]: library versions: OpenSSL 1.0.2f  28 Jan 2016, LZO 2.09
Feb 23 23:41:22 openvpn[1703]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb 23 23:41:22 openvpn[1703]: Control Channel Authentication: using 'static.key' as a OpenVPN static key file
Feb 23 23:41:22 openvpn[1703]: Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Feb 23 23:41:22 openvpn[1703]: Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Feb 23 23:41:22 openvpn[1703]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Feb 23 23:41:22 openvpn[1703]: UDPv4 link local: [undef]
Feb 23 23:41:22 openvpn[1703]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Feb 23 23:41:22 openvpn[1703]: Validating certificate key usage
Feb 23 23:41:22 openvpn[1703]: ++ Certificate has key usage  00a0, expects 00a0
Feb 23 23:41:22 openvpn[1703]: VERIFY KU OK
Feb 23 23:41:22 openvpn[1703]: Validating certificate extended key usage
Feb 23 23:41:22 openvpn[1703]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Feb 23 23:41:22 openvpn[1703]: VERIFY EKU OK
Feb 23 23:41:22 openvpn[1703]: VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=provider.org, CN=server, emailAddress=info@provider.org
Feb 23 23:41:24 openvpn[1703]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Feb 23 23:41:24 openvpn[1703]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Feb 23 23:41:24 openvpn[1703]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Feb 23 23:41:24 openvpn[1703]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Feb 23 23:41:24 openvpn[1703]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Feb 23 23:41:26 openvpn[1703]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Feb 23 23:41:26 openvpn[1703]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-[...]
Feb 23 23:41:26 openvpn[1703]: OPTIONS IMPORT: timers and/or timeouts modified
Feb 23 23:41:26 openvpn[1703]: OPTIONS IMPORT: LZO parms modified
Feb 23 23:41:26 openvpn[1703]: OPTIONS IMPORT: --ifconfig/up options modified
Feb 23 23:41:26 openvpn[1703]: OPTIONS IMPORT: route options modified
Feb 23 23:41:26 openvpn[1703]: OPTIONS IMPORT: route-related options modified
Feb 23 23:41:26 openvpn[1703]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Feb 23 23:41:26 openvpn[1703]: TUN/TAP device tun11 opened
Feb 23 23:41:26 openvpn[1703]: TUN/TAP TX queue length set to 100
Feb 23 23:41:26 openvpn[1703]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Feb 23 23:41:26 openvpn[1703]: /usr/sbin/ip link set dev tun11 up mtu 1500
Feb 23 23:41:27 hour monitor: daemon is starting
Feb 23 23:41:28 openvpn-routing: Configuring policy rules for client 1
Feb 23 23:41:28 openvpn-routing: Creating VPN routing table
Feb 23 23:41:28 openvpn-routing: Removing route for 0.0.0.0/1 to tun11 from main routing table
Feb 23 23:41:28 openvpn-routing: Removing route for 128.0.0.0/1 to tun11 from main routing table
Feb 23 23:41:29 openvpn-routing: Completed routing policy configuration for client 1
Feb 23 23:41:29 custom script: Running /jffs/scripts/openvpn-event (args: tun11 1500 1558)
Feb 23 23:41:29 admin: Started ntpd from .
Feb 23 23:41:29 START_openvpn-event: started [tun11 1500 1558]
Feb 23 23:41:29 STOP_S77ntpd-custom: return code 0
Feb 23 23:41:29 START_guest3_vpn: started [openvpn]
Feb 23 23:41:29 ntpd[1752]: ntpd 4.2.8p4@1.3265 Tue Nov  3 14:54:58 UTC 2015 (3): Starting
Feb 23 23:41:29 ntpd[1752]: Command line: ntpd -c /jffs/etc/ntp.conf
Feb 23 23:41:29 ntpd[1798]: proto: precision = 1.353 usec (-19)
Feb 23 23:41:29 ntpd[1798]: Listen normally on 0 lo 127.0.0.1:123
Feb 23 23:41:29 ntpd[1798]: Listen normally on 1 br0 xxx.xxx.xxx.xxx:123
Feb 23 23:41:29 ntpd[1798]: Listening on routing socket on fd #18 for interface updates
Feb 23 23:41:29 dnsmasq[784]: exiting on receipt of SIGTERM
Feb 23 23:41:29 qtn: bootcfg.tgz exists
Feb 23 23:41:32 crond[792]: time disparity of 298001 minutes detected
Feb 23 23:41:32 dnsmasq[1820]: started, version 2.76-g41a8d9e cachesize 1500
Feb 23 23:41:32 dnsmasq[1820]: warning: interface ppp1* does not currently exist
Feb 23 23:41:32 dnsmasq[1820]: warning: ignoring resolv-file flag because no-resolv is set
Feb 23 23:41:32 dnsmasq[1820]: asynchronous logging enabled, queue limit is 5 messages
Feb 23 23:41:32 dnsmasq-dhcp[1820]: DHCP, IP range xxx.xxx.xxx.xxx -- xxx.xxx.xxx.xxx, lease time 1d
Feb 23 23:41:32 dnsmasq[1820]: using nameserver 127.0.0.1#65053
Feb 23 23:41:32 dnsmasq[1820]: using local addresses only for domain DREAM
Feb 23 23:41:32 dnsmasq[1820]: read /etc/hosts - 34 addresses
Feb 23 23:41:32 dnsmasq[1820]: read /etc/hosts.dnsmasq - 23 addresses
Feb 23 23:41:32 dnsmasq-dhcp[1820]: read /etc/ethers - 23 addresses
Feb 23 23:41:35 STOP_guest3_vpn: return code 0
Feb 23 23:41:35 STOP_openvpn-event: return code 0
Feb 23 23:41:35 openvpn[1703]: Initialization Sequence Completed
Feb 23 23:41:36 scs: disable scs complete
Feb 23 23:42:29 admin: Started transmission-daemon from .
Feb 23 23:42:29 STOP_post-mount: return code 0
Feb 23 23:42:29 rc_service: hotplug 1263:notify_rc restart_nasapps
Feb 23 23:42:30 FTP Server: daemon is stopped
Feb 23 23:42:30 Samba Server: smb daemon is stopped
Feb 23 23:42:30 kernel: gro disabled
Feb 23 23:42:32 Timemachine: daemon is stopped
Feb 23 23:42:32 kernel: gro enabled with interval 2
Feb 23 23:42:33 custom config: Using custom /jffs/configs/smb.conf config file.
Feb 23 23:42:33 Samba Server: daemon is started
Big thx joe
What fw You are use ?
wl -i eth1 revinfo
Result of wl -i eth1 revinfo is in my case:
vendorid 0x14e4
deviceid 0x43a1
radiorev 0x42069000
chipnum 0x4360
chiprev 0x3
chippackage 0x1
corerev 0x2a
boardid 0x665
boardvendor 0x14e4
boardrev P103
driverrev 0x6250e69
ucoderev 0x38b0075
bus 0x1
phytype 0xb
phyrev 0x1
anarev 0x0
nvramrev 0
