I made the mistake of paying attention to AiProtection Network Protection, which suggested that I change my default router login username and password.
Actually, I already had a very secure password, but was still using "admin". I *guess* it was complaining because of "admin".
Should have left it alone, as I don't enable over WAN, and I don't have any open wireless.
Nevertheless, I changed both the username and password and applied. I generated a secure password with LastPass, saved my old user name and password in notes in LastPass (just in case!) and changed the LastPass username and password.
I also switched to https:, it gave me a port number, and I added that to the LastPass entry as well.
After applying, to my horror, I was not I aable to login with the new user name/password. I got locked-out for 5 minutes, retried, etc. After fiddling around, I discovered that the OLD username/password still work! And it's NOT on https or using the new port number.
Here's the strange thing: under Administration/System/router Login Name it shows the NEW router login name! NOT admin. And it also shows HTTPS LAN port with the new port # and authentication method HTTPS. But I can only login with "admin" and the OLD pasword with HTTP!
As well, I am CERTAIN that I DID try the original username/password several times, in my initial panic and it DIDN'T work. But after a while, then it did...
What the heck is going on?
Does it revert if you don't login successfully within x minutes? That's the only thing that could explain this.
I am using firmware version 382.1.2 on an RT-AC88U.
P.S. I got a popup saying "use this new password on your next login".
I am going to try it again. (pressing my luck...)
OK, tried it again. SAME THING. I have to login with the OLD user id/password.
I even tried a reboot. Same thing. I have to use old username/password/http yet System tab shows new login name/https/new port.
See my other post about bouncing radios. Maybe this is somehow preventing the change?
