Tapping into the collective knowledge (newbie needs help)
I’m hoping I can pick on the collective experience of members here to help this newbie get on the right track with my first NAS.
Here is a bit of background on myself:
1. I’ve worked all my life in the IT industry so I am technically aware although I am now retired and for the preceding 10 years I was in management roles and so I have not been involved ‘hands on’. Therefore, although I am technically aware, I would still prefer a solution that is easy to manage.
2. My philosophy is that I would prefer to pay a bit extra for ‘quality’ rather than necessarily go for the cheapest solution available. However, that doesn’t mean that cost is no object; as I said, I am retired.
My current home computing comprises of the following:
• I have a Win Vista based desktop PC that is about 3 years old. It has 2 x 250Gb internal disks that are set up as RAID 1. I did this because at the time I bought the PC my storage requirements were quite small so I thought it worthwhile having the RAID protection.
• However, my 250Gb is now almost full (primarily photos, music and documents) so I need additional storage one way or another.
• I intend to upgrade this machine to 64 bit Windows 7 shortly and, as this will require a complete disk wipe, it would seem sensible to address my storage requirements beforehand.
• I have a 300Gb USB external disk that I use for full/incremental backups of this machine.
• I also have an old Win XP laptop that I use for business purposes. This machine is not backed up at all. This definitely should be backed up.
• The last machine is another oldish Win XP laptop that my wife uses primarily for email etc. Again this machine is not backed up at all. This should be done.
I have done a lot of reading on here, in particular the debate around RAID versus non-RAID and the vulnerability of RAID machines should a NAS controller fail which I had not thought about before. I can see a number of different approaches I could take with various pros and cons and questions as follows.
Option 1 – 2 NASs
• Buy 2 x dual 1Tb NASs and set one up as RAID 1 and the other as JBOD.
• Move all of my photos, music and possibly documents to the 1Tb available space on the RAID 1 NAS
• Use the 2Tb on the JBOD NAS for backup of all three machines.
• Comments:
o The second backup NAS could just be a single 2Tb drive machine to reduce cost.
o The first storage NAS could also be a single drive to reduce cost although I would lose RAID 1 protection
Option 2 – 1 x NAS and backup disk
• Buy 1x dual 1Tb NAS and set it up as RAID 1. Buy a 2Tb USB disk and plug into the back of the NAS.
• Move all of my photos, music and possibly documents to the 1Tb available space on the RAID 1 NAS.
• Use the 2Tb USB disk in the back of the NAS for the backup of all three machines.
• Comments:
Option 3 – 1 x NAS and remove RAID from desktop PC
• Buy 1x 2Tb NAS.
• Remove the RAID 1 set up from the main desktop PC freeing up the second 250Gb disk and move all of my photos, music and possibly documents to the 250Gb available space on the internal disk.
• Use the 2Tb on the NAS for backup of all three machines.
• Comments:
o I have no RAID 1 protection at all now.
o Media/documents would not be available to other machines on the network.
o The additional 250Gb available for media/documents will still only have a limited life at which time I will need a different solution.
I have some questions re the above that I would welcome some advice on:
1. All Options – Does it make sense to move documents to a NAS or to keep them on the main desktop machine?
2. Option 2 – Is a USB disk attached to the back of a NAS still available to backup any PC on the network or just the NAS it is attached to?
3. Option 2 – Is a USB disk attached to the back of a NAS still dependent on the NAS controller (as per the comments re the weakness of RAID 1 disks having a common point of failure) or can the USB disk be unplugged from the NAS, plugged into a PC and accessed by that PC?
4. Option 3 – Would there be significant performance benefits of having my media/documents on the internal desktop drive rather than the NAS?
I would welcome any feedback, comments, questions to help me get off on the right foot.
Many thanks in anticipation of your help,
Graham
Option 1 – 2 NASs
• Comments:
• Comments:
• Buy 1x 2Tb NAS.
• Comments:
Graham
