TCP congestion protocol algorithm options.
133794m3r
As it says I can't seem to find out where the option to install this module is. I know how to get it on standard linux but Idon't think that the router includes it. As modprobe says the module doesn't exist. I've looked in the modules area it is not listed and I'd like to use it with transmission so I can disable QoS but I can't find it so I guess I'm to have to keep it for awhile as I can't find anyway to implement tcp-lp.
I already have uTP enabled btw.
if would help if you actually say about which module you're talking about. There are t least dozen of TCP congestion algos in Linux
D tcp congestion algorithm Asuswrt-Merlin 0
postoronnim-v Windows 11 version 24H2 and Samba protocol. Asuswrt-Merlin 7
