TeamViewer Remote Access Crashing my AC-68 Router or How to Create Multiple WANs
Just Checking
Background:
I just installed TeamViewer 10 software on all my servers and clients in my network so I could remotely access them and basically run the servers headless. TeamViewer is super easy to install and just works for me. I now make all my family and friends install TeamViewer on their computers so I can help them troubleshoot problems without me having to travel to their locations.
I started experiencing problems with my router (Asus RT-AC68 running the Asus-Merlin 374.43_2-069527 fork by John 9527) disconnecting from the network when I was transferring files between HDD's on servers or clients. The files are media files >2GB in size and I am usually transferring multiple files at a time (as much as 90GB). If I went to the individual client/server and transferred the files in the same way, I would have no problems. I only had the problem when I was using TeamViewer software from a client PC (HP Elitebook 8440p, 8460p, or 840G1) to switch between the different servers and clients to do the file transfers or software manipulation.
It didn't matter that I was in the network or outside the network. The router disconnect happened in either one. The router will not reboot and reconnect by itself. I have to physically do a hard reboot on the RT-AC68 router to get it to reconnect to the network. When the disconnect happens, HDD's on the servers that I am transferring data to/from often get dismounted and they have to be remounted by turning them off then on. If the drive I am transferring data from is the OS drive in a laptop, the laptop goes BSOD and crashes with error codes of I/O problems - very disconcerting. I can also get the drives and computers to remount if I reboot the server or client. If I have a network connection, I can do this remotely.
My network consists of 3 - Lenovo TS-140 servers with multiple (5) gigabit ethernet ports, 1 - HP Proliant N54L Microserver with one gigabit ethernet port, 5 - HP elitebook client Laptops with single gigabit ethernet ports, multiple gigabit switches (some managed, most unmanaged), all connected by CAT6 ethernet cable.
I run multiple WAN's; all connected through an Actiontec C1000A in transfer bridge mode to a 40Mbps/20Mbps internet connection. I have no problems with the other WAN's/LAN's or the modem when the problem occurs and I don't have to reset either the modem or other routers on the other LAN's. Only the LAN that I am manipulating with the TeamViewer software disconnects.
I am in the process of trying to troubleshoot where the problem is coming from. I am trying to update the router FW to the latest ver 07 Fork to see if that resolves the problem. I am also trying to switch out the RT-AC68 router for a spare RT-AC66 router (Fork FW ver 04) to see if it is a router problem.
I have talked with half a dozen other people who use TeamViewer software on a daily basis (maybe not ver 10) and none of them have ever experienced this problem. I also sent a note to TeamViewer to see if there may be a bug in the software. Since I use the software for free (it is free for personal use) I can't really expect them to put this as a high priority for them.
Main Question:
Since I have multiple WAN's and routers, combined with servers that have multiple ethernet ports (NIC's are Intel i350-t4's), I was thinking about connecting a couple of the ethernet ports on each server to a different switch and router that has a different LAN IP address such that I could retain connectivity to the servers if one of the LAN routers dropped out. The second LAN would only be connected to the 3 servers that have multiple ethernet connections. I would not be able to "see" the other clients and server that is on the first LAN if the router on the first LAN dropped out but I want to be able to keep the connection to the servers going if the first LAN fails.
Is this scheme reasonable? Would there be conflicts that I need to be aware of? Since TeamViewer connects to the server/client by a unique identifier, would there be a problem if TeamViewer "saw" the same device on multiple WAN's with different IP addresses?
Same thing for a Plex Media Server?
For my server that runs the surveillance and control systems I use a LAN IP address for the discreet devices. Would I have to assign different IP addresses to each device on the different networks to prevent conflicts when I remoted in with the software for that system?
I know that these are probably questions that are specific to my network and hence difficult to answer. I am just trying to determine if it is possible in the first place and whether there is an easier solution that other people have implemented. I have to believe that this is not unique for enterprise level networks - maybe I can use those techniques for myself.
Thanks in advance.
I Remote access to UK content Other LAN and WAN 3
