Telnet from outside (wan/internet)
frequenzy
i have already setup ddns to access the router remotely via http and it works. how can i enable telnet remotely? access from is lan is ok but not from wan.
i understand :) dont worry the router is just for dl and kids internet.
Set up a vpn for local access. You should be able to connect with telnet while connected to the vpn. I would suggest you use the pptp vpn at first, very easy to set up.
Honest question: I'm curious why you would pick telnet over ssh. Is there something telnet provides that ssh does not?
