Terrible perfs with RT-N66U + late-2013 MacBook Pro
Tallan
I encounter a huge latency problem with every 3 streams MCS speeds on a MBP late-2013 MBP.
I tested firmware 3.0.0.4.260, 3.0.0.4.374.720, 3.0.0.4.374.979, and merlin 3.0.0.4_374.35_4
Everytime same thing, catastrophic ping times with the router :
64 bytes from 192.168.2.1: icmp_seq=1349 ttl=64 time=1.278 ms
64 bytes from 192.168.2.1: icmp_seq=1350 ttl=64 time=1.274 ms
64 bytes from 192.168.2.1: icmp_seq=1351 ttl=64 time=1.141 ms
64 bytes from 192.168.2.1: icmp_seq=1352 ttl=64 time=211.322 ms
64 bytes from 192.168.2.1: icmp_seq=1353 ttl=64 time=131.835 ms
64 bytes from 192.168.2.1: icmp_seq=1354 ttl=64 time=52.215 ms
64 bytes from 192.168.2.1: icmp_seq=1355 ttl=64 time=280.167 ms
64 bytes from 192.168.2.1: icmp_seq=1356 ttl=64 time=200.603 ms
64 bytes from 192.168.2.1: icmp_seq=1357 ttl=64 time=121.299 ms
64 bytes from 192.168.2.1: icmp_seq=1358 ttl=64 time=41.357 ms
64 bytes from 192.168.2.1: icmp_seq=1359 ttl=64 time=269.228 ms
Aside of that, my old 2011 MBP on 2 streams MCS 14 300Mbps, 5GHz never showed any sign of problem :
64 bytes from 192.168.2.1: icmp_seq=0 ttl=64 time=0.874 ms
64 bytes from 192.168.2.1: icmp_seq=1 ttl=64 time=0.759 ms
64 bytes from 192.168.2.1: icmp_seq=2 ttl=64 time=0.782 ms
64 bytes from 192.168.2.1: icmp_seq=3 ttl=64 time=0.785 ms
Is it possible to disable a range of MCS index on the RT-N66U on the merlin firmware ?
rate limited, problem remains the same
OK, Reading the Asus source code, I successfully managed to limit MCS, turning the RT-N66U into 2x3 MIMO on 5GHz (wl1)
nvram set wl1_txchain=5
nvram set wl1_rxchain=5
nvram commit
reboot
Now, both MBP, the new retina and the old one, synchronize in MCS 15 at 300MBps in 5GHz (40MHz channels).
Side-by-side, the problem persists on the Retina MBP while the 2011 one still works like a charm with 1ms ping.
Not knowing exactly which stream to keep, I tried 0-1 and 0-2. Same result.
Does nobody faces this problem ?
What are your ping time on your Retina MacBook Pro Mavericks 10.9.1 ?
I would tend to think it's a mac problem, but could you check on your side and report successful firmware versions on RT-N66U working with Mavericks retina MBP (preferably late-2013) in 300 and 450Mbps with rock solid 1ms ping ?
This is the first time I see that solution being used with Macs. Usually the fix most people use is enable 802.11d+h support. If you use my firmware I exposed the nvram setting on the Wireless -> Professional page. Might be worth a shot.
solved !
Exploring the Mac way on another wireless infrastructure, I found that the problem is indeed a insane Maverics 10.9 issue.
The OS seems to put the wireless interface into sleep mode after 0.2s.
So with a default delay of 1s between icmp frames, ping is not able to keep the interface up for itself.
If I cut the delay to 0.2s (ping -i 0.2), the problem is gone !!
I put the tx/rx_chains back to 7, the Retina MBP is now synchronized to 450Mbps and ping time is clean around 1ms as it should always have been.
Please could you explain how you manage to do that
"If I cut the delay to 0.2s (ping -i 0.2), the problem is gone !!
I put the tx/rx_chains back to 7, the Retina MBP is now synchronized to 450Mbps and ping time is clean around 1ms as it should always have been."
which setting is it ?
