[Test] Asuswrt-Merlin with HTTPS support for DDNS
RMerlin
Asuswrt-Merlin dev
Staff member
Hi everyone,
I need people to test a new version of ez-ipupdate that now supports HTTPS for updating your DDNS service (previously ez-ipupdate only supported HTTP - that's right, zero encryption...)
https://asuswrt.lostrealm.ca/test-builds
The builds are in the DDNS Test folder:
Please report which DDNS provider you are using, and your results (good or bad).
These builds are ONLY intended for testing DDNS services.
Tested OK:
DNS-o-Matic
No-IP
Namecheap
Asus
DynDNS
Using DNSomatic to update my DuckDNS DNS service.
 start_ddns: update WWW.DNSOMATIC.COM dnsomatic, wan_unit 0
Sep  1 09:52:52 ddns_update: ez-ipupdate: starting...
Sep  1 09:52:52 ddns_update: connected to updates.dnsomatic.com (**.215.92.***) on port 443.
Sep  1 09:52:53 ddns_update: request successful
Sep  1 09:52:53 ddns_update: asusddns_update: 0
Sep  1 09:52:53 ddns: ddns update ok
Test build seems to work fine.
Sep  1 10:14:33 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Sep  1 10:14:33 ddns_update: ez-ipupdate: starting...
Sep  1 10:14:33 ddns_update: asus_private() interface =eth0
Sep  1 10:14:33 ddns_update: g_asus_ddns_mode == 2
Sep  1 10:14:34 ddns_update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 443.
Sep  1 10:14:34 ddns_update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Sat, 01 Sep 2018 08:14:33 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Sep  1 10:14:34 ddns_update: retval= 0, ddns_return_code (,200)
Sep  1 10:14:34 ddns_update: asusddns_update: 0
Sep  1 10:14:34 ddns: ddns update ok
Test build seems to work, Not sure about the return entry. But this is what i get.
edit: Guess the ddns_return_code (,200) is : This class of status code indicates that the client's request was successfully received, understood, and accepted
I tested with DNS-O-Matic paired with ydns.io
Sep  1 16:59:59 watchdog: start ddns.
Sep  1 16:59:59 rc_service: watchdog 363:notify_rc restart_ddns
Sep  1 16:59:59 start_ddns: update WWW.DNSOMATIC.COM dnsomatic, wan_unit 0
Sep  1 17:00:00 ddns_update: ez-ipupdate: starting...
Sep  1 17:00:04 ddns_update: connected to updates.dnsomatic.com (67.215.92.215) on port 443.
Sep  1 17:00:06 ddns_update: request successful
Sep  1 17:00:06 ddns_update: asusddns_update: 0
Sep  1 17:00:09 ddns: ddns update ok
Sep  1 17:00:09 ddns_update: exit_main
Using asus.com on the RT-AC86U. Success.
Sep  1 16:29:02 rc_service: watchdog 783:notify_rc restart_ddns
Sep  1 16:29:02 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Sep  1 16:29:02 ddns_update: ez-ipupdate: starting...
Sep  1 16:29:02 ddns_update: asus_private() interface =eth0
Sep  1 16:29:02 ddns_update: g_asus_ddns_mode == 2
Sep  1 16:29:03 ddns_update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 443.
Sep  1 16:29:04 ddns_update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Sat, 01 Sep 2018 14:29:03 GMT^M Server: Apache^M X-Powered-By: PHP/5.6.30^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Sep  1 16:29:04 ddns_update: retval= 0, ddns_return_code (,200)
Sep  1 16:29:04 ddns_update: asusddns_update: 0
Sep  1 16:29:04 ddns: ddns update ok
Sep  1 16:29:04 ddns_update: exit_main
Namecheap works....
Sep 1 11:15:40 start_ddns: update WWW.NAMECHEAP.COM namecheap, wan_unit 0
Sep 1 11:15:40 ddns_update: ez-ipupdate: starting...
Sep 1 11:15:41 ddns_update: connected to dynamicdns.park-your-domain.com (104.219.249.157) on port 443.
Sep 1 11:15:41 ddns_update: request successful
Sep 1 11:15:41 ddns_update: asusddns_update: 0
Sep 1 11:15:41 ddns: ddns update ok
Sep 1 11:15:41 ddns_update: exit_main
but
it breaks with let's encrypt
i have put
hostname: home
domain name: customname.com
won't generate a certificate.
previously, I'd put hostname: home.customname.com when using custom ddns-script file and then it works.
unfortunately, putting home.customname.com for my hostname generates an error.
dnsomatic works
Sep 1 11:24:58 start_ddns: update WWW.DNSOMATIC.COM dnsomatic, wan_unit 0
Sep 1 11:24:58 ddns_update: ez-ipupdate: starting...
Sep 1 11:24:58 ddns_update: connected to updates.dnsomatic.com (67.215.92.215) on port 443.
Sep 1 11:24:59 ddns_update: request successful
Sep 1 11:24:59 ddns_update: asusddns_update: 0
Sep 1 11:24:59 ddns: ddns update ok
Sep 1 11:24:59 ddns_update: exit_main
however, won't generate a certificate similar to above.
Doesn't Let's Encrypt require the use of Asus's own DDNS, to achieve DNS-based validation?
Correct. Asus uses many standard HTTP response code to provide results. 401 would be an authentication failure for example. 200 indicates the update was successful.
I got a let’s encrypt certificate working with my home.customname.com hostname through Namecheap via a custom ddns-start script
Then this has nothing to do with ez-ipupdate. The test is simply to determine if HTTPS-based update work, it won't add LE support to services that didn't previously have it.
Understood.
Not sure if it worth adding a note that let’s encrypt isn’t supported for anything other than Asus’s DDNS?
Understood.
Asus never made it clear what was actually required. During development, they even added a second lighttpd instance to the firmware, probably so it could handle LE validation even with third party DDNS services. Since I couldn't keep track of their work, I never knew for sure if that particular feature was ever finalized or not.
It is working with free-dns and 86U, thx Eric!
There are no "free-dns" service in Asuswrt. Which actual provider were you using?
About to give the test run a spin on my 68U. Can anyone confirm whether these are built upon the 384.6 codebase?
384.7_alpha2
