test methodology question
pete y testing
hi guys
first post here , but i am a long time poster and tester on the australian adsl user forums known as whirlpool forum
my initial question is could you plz let me know what tools and methodology you guys use to gain your throughput results
the reason behind this is i would like to try and at least test on similar platforms to gain similar results and keep some consistency to spec and results
i am currently testing the fritzbox 7390 and asus rt-N56U and wish to incorperate throughput results in the same format as you guys do to avoid confusion for the end user
thanks in advance
pete
