I see this as enabled and regarding VLANs, I don't use one? I don't think I do, from what I read you set it up with many network devices, my setup is just 2 PC's and a smart TV with just my Asus router.
I consulted with ChatGPT on what this setting does:
I then ask "does this tagging add performance overheads?":
So as I would of imagined, negligible. Which I don't mind, since I've done tons of tweaks for they all add up (like in an F1 car).
My question, do you actually think this enabled setting is applying VLAN tags to my network packets? If I'm not using a VLAN?
Thanks.
When the "802.1Q" setting is enabled on your ASUS router, it allows the router to add VLAN tags to network packets. This tagging helps in segmenting network traffic, which can be useful in scenarios where you want to separate different types of traffic for security or management purposes. For example, if you have devices that need to be on separate networks for privacy reasons (like guest Wi-Fi), VLAN tagging can help achieve this segmentation without needing physical network separation.
Enabling VLAN tagging itself doesn't add significant performance overhead to your network. The overhead is minimal and generally negligible for typical home or small office network setups. However, in extremely high-performance or heavily loaded network environments, the additional processing required for VLAN tagging could potentially introduce a small amount of latency. For most users, the benefits of VLAN segmentation outweigh any minimal performance impact from VLAN tagging.
Thanks.
