The dreaded "HTTPS is a relatively more secured web access protocol. We strongly suggest to enter the ASUS router setting page via HTTPS protocol."
Kapitikarl
Hi All,
Can't seem to fix the dreaded "HTTPS is a relatively more secured web access protocol. We strongly suggest to enter the ASUS router setting page via HTTPS protocol." window when I log into my RT-AC88U router.
So far, I have:
Factory reset - both within the software and also by pressing the reset button at the back of the device - before and after updating [problem remains]
Rolled back to Asus WRT and then to WRT Merlin [problem remains]
Changed Local Access Config Authentication method from Default to HTTPS [cannot access my router at all]
Tried exporting a new security certificate [problem remains and also generates it for a router at IP address 192.168.1.1] whereas my router IP has been set to 192.168.2.1
I have had this problem before, and I checked previous messages, attempted to find other posts on this forum, good old google, asus support and you tube. Either I am not using the right search terms or it is something super simple that has slipped my mind.
Any suggestions folks?
Yes there is and I am using Edge. Is it browser related? Should I be worried? Any settings in the browser I can apply?
If I wanted to sign-in with https using the correct certificate, how do I set that up?
How do I set / import the Asus certificate good in android?
It worked perfectly for my Windows pc.
As far as I can see Android no longer accepts custom root CA certificates. In the past you would install them at Settings > Security & privacy > More security settings > Install from device storage
Yes, that's right, so did I it .
I can't move it from from user to system.
After a reboot I get the notification, that a certificate is installed by a unknown company (Asus).
I can disable the notification in it, but after a reboot it is visible.
It works, guess it Android related 😉
