Auximen
If connect the modem Huawei E3272 (RU Megafon M100-4) to ASUS AC68U (Merlin 376.48_1), the router sees the modem, establishes a connection, assign an external IP address and DNS address, in Network Utilities works Ping to Google.com, but on client devices connected by WiFi no Internet. Internet only appears when in manual mode in Map network break and reconnect the Internet connection. There is a problem with this option disabled "Dual WAN" and when the option "Dual WAN" when the primary WAN set USB, Secondary WAN - WAN. If enabled Dual WAN and set USB Secondary WAN, internet appears on the devices immediately after booting the router. I think there is a bug in the firmware, which does not allow to distribute Internet to devices with this option disabled Dual WAN or when the option Dual Wan enabled and Primary WAN set USB.
Huawei E3272 firmware E3272s-153_21.470.09.00.00_general, AT^SETPORT="A1,A2;10,12,16,A1,A2" (default presets). Tried to use different firmware, including firmware for Huawei E3276 and tried to set the modem to "modem only" (AT^SETPORT="FF;10,12"), is present in all variants of the problem described above.
I apologise for my low knowledge of English, i'm working on it).
http://imagizer.imageshack.com/img674/2213/0huDbk.png
http://imagizer.imageshack.com/img673/180/C2jMuY.png
