Do the clients use different user names, or are they sharing one user name?PPTP
There is an error. You cannot use 192.168.0.x because that is your LAN.IP Pool DHCP I have changed. not earn
Aug 8 22:21:56 pptpd[3784]: CTRL: Client aaa.bbb.ccc.ddd control connection started
Aug 8 22:21:56 pptpd[3784]: CTRL: Starting call (launching pppd, opening GRE)
Aug 8 22:21:56 pptp[3786]: Plugin pptp.so loaded.
Aug 8 22:21:56 pptp[3786]: PPTP plugin version 0.8.5 compiled for pppd-2.4.7, linux-2.6.22.19
Aug 8 22:21:56 pptp[3786]: pppd 2.4.7 started by admin, uid 0
Aug 8 22:21:56 pptp[3786]: Using interface ppp10
Aug 8 22:21:56 pptp[3786]: Connect: ppp10 <--> pptp (aaa.bbb.ccc.ddd)
Aug 8 22:21:56 pptp[3786]: MPPE 128-bit stateless compression enabled
Aug 8 22:21:56 pptp[3786]: Cannot determine ethernet address for proxy ARP
Aug 8 22:21:56 pptp[3786]: local IP address 192.168.1.1
Aug 8 22:21:56 pptp[3786]: remote IP address 192.168.10.2
Aug 8 22:23:42 pptpd[3800]: CTRL: Client eee.fff.ggg.hhh control connection started
Aug 8 22:23:42 pptpd[3800]: CTRL: Starting call (launching pppd, opening GRE)
Aug 8 22:23:42 pptp[3801]: Plugin pptp.so loaded.
Aug 8 22:23:42 pptp[3801]: PPTP plugin version 0.8.5 compiled for pppd-2.4.7, linux-2.6.22.19
Aug 8 22:23:42 pptp[3801]: pppd 2.4.7 started by admin, uid 0
Aug 8 22:23:42 pptp[3801]: Couldn't allocate PPP unit 10 as it is already in use
Aug 8 22:23:42 pptp[3801]: Using interface ppp11
Aug 8 22:23:42 pptp[3801]: Connect: ppp11 <--> pptp (eee.fff.ggg.hhh)
Aug 8 22:23:45 pptp[3801]: MPPE 128-bit stateless compression enabled
Aug 8 22:23:45 pptp[3801]: Cannot determine ethernet address for proxy ARP
Aug 8 22:23:45 pptp[3801]: local IP address 192.168.1.1
Aug 8 22:23:45 pptp[3801]: remote IP address 192.168.10.3
Does the Zyxel support "PTPP passthrough"?Doesn't work from computers 6,7.
Welcome To SNBForums
