The router has a frightening log
FIN
Does anyone know what's going on with the router? Periodically, this information appears in the log. At the same time, the Internet, wifi and time are lost
  • syslog.txt
So your router rebooted .
You'll need to provide a lot better infomation if you want people to help you.
What router? What firmware version? What scripts are you running?
Your router has been rebooted for some reason. That's just a Boot log. The log is ok. You need to find something makes your router rebooted like a defective AC Adapter, a device which effects on your router something like that.
Possibility.
a defective AC Adapter > a connected device.
I hate AC88U. I think AC88U is a defect itself.
  • Like
Reactions: FIN
Reading LOGs are often very exhausting but I found something else which might need some attention:
May 5 08:05:05 kernel: Bad eraseblock 641 at 0x000005020000
May 5 08:05:05 kernel: Bad eraseblock 679 at 0x0000054e0000
May 5 08:05:05 kernel: Bad eraseblock 732 at 0x000005b80000
May 5 08:05:05 kernel: Bad eraseblock 733 at 0x000005ba0000
May 5 08:05:05 kernel: Bad eraseblock 852 at 0x000006a80000
May 5 08:05:05 kernel: Bad eraseblock 872 at 0x000006d00000
May 5 08:05:05 kernel: Bad eraseblock 888 at 0x000006f00000
May 5 08:05:05 kernel: Bad eraseblock 889 at 0x000006f20000
May 5 08:05:05 kernel: Bad eraseblock 966 at 0x0000078c0000
May 5 08:05:05 kernel: Bad eraseblock 967 at 0x0000078e0000
Didn't anyone notice that? :D
May be your NVRAM has some difficulties (is failing or will fail soon).
Bad blocks are pretty common, they get automatically managed by a badblock table.
  • Like
Reactions: FIN
AC88U with 3.0.0.4.386.43129. DHCP on, trendmicro on.
LAN 8 - 100 Mbps, but there is nothing pluged in.
With 2 aimesh node ac68u. other Lan devices thrue HPE 1920 Switch. CPU temperature : 65C
there were no reboots today. but yesterday's case was not the first.
and which model is better to buy for replacement? AX88U-?
AX86U + an unmanaged switch for more ports. I had horrible exp with AC88U. I don't use them anymore. AX88U is not much that different.
  • Like
Reactions: FIN
With 2 aimesh node ac68u. other Lan devices thrue hp switch. CPU temperature : 65C
Turn off all AiProtection options. And watch it for a while. It happens again? remove devices one by one.
It happens again? Use a different AC Adapter and watch it. I think using a different adapter is better.
WAN Connection: Fail to connect with some issues - every 4 houres. Router dying or provider is too bad.
  • syslog (1).txt
If it has no warranty you could just try to flash a firmware on it ( stock -> merlin) may be that helps but otherwise don't waste precious life time and look out for another router.
  • Like
Reactions: FIN
