I just noticed the announcement of the N2310 two-drive-bay product.
A few minutes reading specs..
Good price point.
Good stylistic design
Software sounds good. I didn't see Airprint support (so iPAD, iPhone, MACs can print via the NAS to non-airprint printers on the LAN. I do that w/my Synology and it saved having to buy a new printer. Maybe that capability is there but not mentioned in spec. sheet.)
USB port on front panel is blank. Darn - you have to get to the back to plug in a drive or thumb drive. Or use a cabled hub.
Both rear ports are USB3-blue but one is actually USB2. No biggie.
No SD card slot - I use that on the Synology with an ever-present 32GB SD card for VVIP file backup. I don't use it for reading a card from a camera.
This looks good vs. the two-bay products from Synology & QNAP. But consider the above comments- and vs. the good price.
Quick scan - the N2310 isn't on the usual Internet tech sellers yet.
Good price point.
