This is a quick validation question.
vitahe2015
Can I populate all 4 EHWIC slots in a Cisco 2911 router with VWIC3-4MFT-T1/E1 cards supporting clear channel T1 data traffic?
Or do I need a higher performance router inthe 3900 series to do this?
The data sheets lead me to the conclusion that I can but I just want to validate this.
So what I the processing power difference between the VWIC3-4MFT-T1/E1 versus an HWIC-4T1/E1?
One of my fellow engineers opened a TAC case and was told that for a 2911 would have serious performance issues if it had more than two of these cards.
The application is for just Clear Channel Point to point T1 traffic. Nothing fancy.
The HWIC cards are $900 list less than the VWIC3 card. Is the performance worth it?
If you are just doing garden variety T-1 the Hwic will do the job.
the Vwic3 supports much more voice functionality (drop insert...)
OK, But then I see in a document that Cisco is saying that the 2911 will only support 1 HWIC-4T1/E1. and the 2921 and 2951 will only do 2 of these cards. I have to go to a 3925 to do 3 or 4 which is where I want to be. Or do I jump the shark and go to an ASR1002?
Verified that from here:
http://www.cisco.com/c/en/us/produc...dules/product_data_sheet0900aecd80710c77.html
The ASR is Fast . . . like . . . REALLY Fast.
From my personal experience the ASR1002 is about 3x as fast as a 3945E which itself is 2x as fast as a 3945. Take from that what you will as a comparison to the 3925.
