marclapointe
hi,
similar problem...
trying to figure out what is the best option for network deployment in large building 40mx20m 3 - floors
bought recently the router N55U and configure a primary wireless network and 2 guest networks (2.4Ghz and other 5Ghz)
But the signal is way too weak to cover the whole building.
find below a brief description of the situation :
___________
/____________\
|_________x_| first floor with offices with actual N55U router (x)
|_1_________| ground floor with and 1st Access Point (1) for offices behind the auditorium
|________2__| basement with 2nd Access Point (2)
1- In this configuration is APs the right solutions
2- I was tempted to go for this Asus RT-N15U that support apparently multi SSIDs but I am not quite sure this can be done in my situation where I would use this device as an AP to extend my signal for the primary network and the guest network.
Can you advise as what is the best solution to extend both networks (primary and guest)?
similar problem...
___________
/____________\
