Time for a Factory Reset - Asus DSL-AC68U??
DaVoodoo
Greetings.
I am running the router with the latest stable gnuton/merlin firmware.
I am getting the following in my log file:
dnsmasq-dhcp[231]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60s)
and
smbd[331]: smbd_accept_connection: sys_fork() failed: Cannot allocate memory
Also, I see that my NVRAM usage is 61947 / 65536 bytes. Is it time for a factory reset or is there something else I can try?
Greetings.
and
Are you running any Trend Micro features?
OE
Yes, should it be disabled?
Sent from my SM-G970F using Tapatalk
I've seen it crash and consume memory. Administration\Privacy\Withdraw will disable all of it, but if troubleshooting, I would reset and configure and not enable it. Your call... my suspicions began with 86U 45149. I'm holding at 45717 with it disabled.
OE
