Time not sequential in log since upgrade to 386.4
Morris
I find this rather odd and don't see a reason for it. Device is RT-AX86U. Sample Log with bolded variations:
Jan 10 10:08:03 dnsmasq-dhcp[2992]: DHCPREQUEST(br0) 192.168.2.222 48:8f:5a:c3:fc:ac
Jan 10 10:08:03 dnsmasq-dhcp[2992]: DHCPACK(br0) 192.168.2.222 48:8f:5a:c3:fc:ac MikroTik-CRS305
Jan 10 10:08:32 dnsmasq-dhcp[2992]: DHCPREQUEST(br0) 192.168.2.66 f0:27:2d:a0:70:96
Jan 10 10:08:32 dnsmasq-dhcp[2992]: DHCPACK(br0) 192.168.2.66 f0:27:2d:a0:70:96
Jan 10 10:09:15 dnsmasq-dhcp[2992]: DHCPREQUEST(br0) 192.168.2.40 c8:ff:28:7c:2b:92
Jan 10 10:09:15 dnsmasq-dhcp[2992]: DHCPACK(br0) 192.168.2.40 c8:ff:28:7c:2b:92
Jan 10 10:38:06 dnsmasq-dhcp[2992]: DHCPREQUEST(br0) 192.168.2.3 b4:f7:a1:b3:80:68
Jan 10 10:38:06 dnsmasq-dhcp[2992]: DHCPACK(br0) 192.168.2.3 b4:f7:a1:b3:80:68 android-9782aa618bd2546c
Jan 10 10:56:35 dnsmasq-dhcp[2992]: DHCPREQUEST(br0) 192.168.2.31 ac:67:84:f1:45:50
Jan 10 10:56:35 dnsmasq-dhcp[2992]: DHCPACK(br0) 192.168.2.31 ac:67:84:f1:45:50
Jan 10 16:01:51 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link DOWN.
Jan 10 16:01:51 kernel: br0: port 1(eth4) entered disabled state
Jan 10 16:01:51 kernel: br1: port 2(eth4.501) entered disabled state
Jan 10 16:01:51 kernel: br2: port 2(eth4.502) entered disabled state
Jan 10 11:06:53 wlceventd: wlceventd_proc_event(469): wl0.2: Deauth_ind 04:03:D6:75:85:28, status: 0, reason: Unspecified reason (1)
Jan 10 11:06:53 wlceventd: wlceventd_proc_event(505): wl0.2: Auth 04:03:D6:75:85:28, status: Successful (0)
Jan 10 11:06:53 wlceventd: wlceventd_proc_event(534): wl0.2: Assoc 04:03:D6:75:85:28, status: Successful (0)
Jan 10 11:06:53 hostapd: wl0.2: STA 04:03:d6:75:85:28 IEEE 802.11: associated
Jan 10 11:06:53 hostapd: wl0.2: STA 04:03:d6:75:85:28 RADIUS: starting accounting session 72A78D818A849710
Jan 10 11:06:53 hostapd: wl0.2: STA 04:03:d6:75:85:28 WPA: pairwise key handshake completed (RSN)
Jan 10 11:06:53 dnsmasq-dhcp[2992]: DHCPDISCOVER(br0) 04:03:d6:75:85:28
Jan 10 11:06:53 dnsmasq-dhcp[2992]: DHCPOFFER(br0) 192.168.2.77 04:03:d6:75:85:28
Jan 10 11:06:56 dnsmasq-dhcp[2992]: DHCPDISCOVER(br0) 04:03:d6:75:85:28
Jan 10 11:06:56 dnsmasq-dhcp[2992]: DHCPOFFER(br0) 192.168.2.77 04:03:d6:75:85:28
Jan 10 11:06:56 dnsmasq-dhcp[2992]: DHCPREQUEST(br0) 192.168.2.77 04:03:d6:75:85:28
Jan 10 11:06:56 dnsmasq-dhcp[2992]: DHCPACK(br0) 192.168.2.77 04:03:d6:75:85:28
Jan 10 16:07:05 kernel: wl0: random key value: 7581E8126DB795573C5C00CB1ED479FE652D7542991900D88F4B56BA823FE777
Jan 10 11:07:05 hostapd: wl0.2: STA 04:03:d6:75:85:28 IEEE 802.11: disassociated
Jan 10 11:07:05 wlceventd: wlceventd_proc_event(486): wl0.2: Disassoc 04:03:D6:75:85:28, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Already noted in the beta thread.
Thank you Colin. I would not know about that. Looks like it still needs fixing. Do you know if the time stamp or the sequence is what is correct?
From what I can remember I don't think it's something RMerlin considers worth looking into. The kernel messages are in UTC whereas the other messages are in the local time zone.
Thank you,
Then they are sequential and it's easy to look at if something happens.
Same in the factory firmware.
Version 3.0.0.4.386.46061
2022/01/11 75.31 MBytes
ASUS RT-AX86U Firmware version 3.0.0.4.386.46061
>>> snip <<<
Fixed time zone error.
>>> snip <<<
http://www.snbforums.com/threads/asus-rt-ax86u-firmware-version-3-0-0-4-386-46061-2022-01-11.76716/
http://www.snbforums.com/threads/as...-0-0-4-386-46061-2022-01-11.76716/post-736445
Two useful links for those who want more detail.
A LOT has been fixed after the untested stock firmware for the RT-AX86U was provided to the Maestro.
Great to see - now we must wait patiently for the next Merlin release.
I only hope this time they [Asus] provide stock GPL's that are actually released versions so that Merlin can focus on his wizardry and not be distracted by the alpha and beta glitches which relate to closed source portions of the code over which he has no control. :).
"time zone error" could mean anything. I think it's more likely to be an actual time zone problem (of which there are many) they've fixed rather than this kernel timestamp issue. But one can always hope.
