Time schedule - Firewall Network Services Filter
Lombiz
I want to block all internet access at night with router Asus RT-AC66U
Blocking ports 80 & 443 should do that as far as I understand.
Put in dest. port 80/443 but cannot get it to work between certain hours.
Only when timerange is 00:00-23:59 both blacklist or whitelist works.
So if I blacklist internet is off and whitelist it is on, but if I i.e. set blacklist 01:00-06:00 it doesnt work regardless of time of day.
Attached an image of settings.
Am I missing something very simple or doing/thinking wrong.
Googled and searched so many forums but cannot find any info.
Any help highly appreciated.
Br, Peter
Do you have NAT acceleration enabled? It makes the time schedules lag quite a bit as it skips the CPU for existing sessions.
Had it on auto but changed to disable. Still doesnt work! :(
Might Merlin firmware improve function and stability with what I am trying to do?
Thx!
