I have a RT-AC68P with Merlin 378.52
I want to be able to use the AiProtection - Time Scheduling to setup a time the ip address can access the inter net and other ports. I got it to work great. IP range ( .50 -.60 )
( I'm using the Manually Assigned IP around the DHCP List .)
( It assigns the IP address to a MAC address. )
But, some times i want to block the same Ip range ( .50-.60 ) all day.
the problem is , to do it in AiProtection - Time Scheduling. I have to edit all 10 clients list . Then put it back when done.
I have been setting it up per day and saving them a restore and loading them as i need them.
But,I don't like the ideal of loading restores a lot.
this is what i have :
Got a bank of ip address 40-80.
ip 50-60 can only be online 1-5PM every day. ( setup in Time Scheduling )
But on the day , I want to not give ip 50-60 access I want to turn it off. ( it is random days )
But, still allow the rest to use online. IP 40-49 & 61-80 to be online
My questions are:
Can I use the firewall settings ( network Services Filter ) to override the Time Scheduling ?
Does NSF override TS , TS override NSF, or do they not work together?
Does anyone have and ideals on the easiest way to do this?
or another way of doing it?
in DD-wrt.Time Scheduling was based on rules and ip/mac address could be added to multi rules.
I could add one rule in the Time Scheduling that block the set of IPs all day. Turn that rule on and off.
in Merlin it is base on Mac, but you can not add multi Mac address.
If you could, i could just check and uncheck the one i want to use.
Can anyone help me please?
My questions are:
