Very exhausted with the readings of threads on power vs implementation of protocols, so going to ask for those who are truly the geeks to recommend a solution.
Scenario: The environment is a rambler style home with Wi-Fi SMART appliances on both ends of the house with bedrooms in middle. The backbone is gigabit supported with wired CAT 6 wired drops each end.Devices floating from one end of the house to the other are IOS devices (iPad 3&4 devices). Smart Devices stream from a Synology NAS unit. Present network performs like it should and as one would want
Problem/Experience: Periodical weak singles when passing through zones and takes the IOS devices sometimes a few minutes to negotiate a connection with the stronger router. If too long, can simply turn Wi-Fi off and back on again to fix problem.
Requirement: Remove the 3 dlink 1525 routers(placed East-Center-West) and solution with a Centered placed solution that will cover the WHOLE house. Assumption should include new 802 variations but would rather have solid coverage vs any new implementation to play with.
Any SOLID recommendations?
