I'll just start this out with posting a picture:
Isn't that a pretty...
Gear list:
Switch A: Netgear GS108T
Switch B: Cisco SLM2008
Router: Ubiquiti EdgeRouter PoE-5
WIFI: Asus RT-AC68U (AP mode)
Additions (to be connected to Switch B):
NAS - Brand/Model TBD
VPN Router - Most likely a Ubiquiti EdgeRouterX
Left side is my current configuration. WAN comes in, is patched directly to LAN1 and connects to the router, which is then connected on to my wifi and also patched back into the rest of my LAN. Simple enough. There are several reasons as to why the router is not connected where switch 1 is, it's not currently an option unfortunately.
Right side is what I have in mind. WAN comes in to switch A (VLAN2 configured port), goes via the LAG trunk to switch B (VLAN2) and on to the router (and wifi), then patches the traffic back to the switch (VLAN1) over the trunk and on out to the rest of my LAN. Unfortunately there's an error in the right side drawing, my wifi AP will be connected to switch B, not the router.
I didn't include it in the sketch, but I also plan a VLAN3 for maintenance purposes. Don't want to leave those configuration UIs (looking at you Netgear...) open on the main LAN.
So, now. Question time:
Aside from looking fancier on paper and having cool abbreviations in it, is my suggested change actually better than what I have (as in potentially faster with 25-30 devices distributed fairly evenly over LAN and WIFI)? Obviously it adds complexity, but I don't have a problem with that. I also plan to connect a second router to be used for VPN (which will require its own local VLAN) and a NAS (for backups and streaming media) to switch B, which is mainly why I'm considering this change in the first place.
Thank you for reading, and I apologise for my lazy sketch. Oh, and if you feel there might be a better way to sort out this mess, I'm open for suggestions. Costs *is* an issue though, I already have all the hardware needed to make my suggestion above happen. If needed I can buy some additional low cost items, but suggestions about switches with 10Gbit trunking ports and whatnots would be a waste of time (I would if I could).
Gear list:
