Tomato Shibby for RT-N66U
SDK5 driver has better range. SDK6 has a reduced range, but better performance/compatibility for some people - you might need to experiment.
Updating
It is best to re-enter all of the data or can the config file be used after updating firmware?
Since these two Tomato builds use a different SDK, you will most likely have to reset to factory defaults and reconfigure manually.
