Hi
Previously in FW RT-AC66U_380.62_1 I use without problem VPN Tracker software for admin remote office behind TOR switched ON on my router. As I not mistaken VPN Tracker use UDP 500, 143, 53 .
MY router RT-AC66U version B0
After any new FW Upgrade I can't use it any more - ports are blocked
I do rooter RESET , write PortForward or PortTriger but it doesn't help
Is any possibility to start TOR on router make same changes and use selected LAN host behind it to use VPN Tracker May be some script or change setting using SSH
And what settings must be for System log for maximum information output
Default is notice/debug ( Administration -> Systen -> Logging )
Thanks for any advice
Best regards Sergey
Best regards Sergey
