Tp-Link AC1750 Archer C7 - Deal?
iGirl
Tp-Link AC1750 Archer C7 (Not V1) Ethernet Wireless Router - Jet.com $62 after 20%off (First Customer) -
Use the coupon SCARYMOMMY2015 or ANDROID20 at checkout for first time buyer. If you waive return you can get it for 1.5% less.
https://jet.com/product/TP-LINK-A...28e9e1b48a
The price seems good, but not sure about the quality of TP-Link and Jet is a bit of a hot mess.
My Linksys EA6500 might be flaking out so I'm looking at options...this being one.
Archer C7 is a decent router and the price is very good.
The router is arguably the most critical computer in your network. Get the best you can afford. Although mine are free from T-Mobile, I would not hesitate to buy the same model from Amazon if I had to replace them.
Thanks for the feedback, The Linksys I have is AC1750 so this maybe isn't an upgrade, they've jacked the price now too so will look for some other options...
My sister paid $100 for hers. Its not a bad router. Has great range from what I seen.
