TP-Link Archer C9 vs Netgear R6700 vs Asus RT-AC68U (T-Mobile Version)
Dioc
I'm currently deciding between these 3 routers for a 1200 foot apartment with 400mb spectrum internet. The Sagecom router from Spectrum is having troubles reaching the outskirts of the apartment so I need something that has good quality range. The prices between these 3 units is (Archer C9 $89, R6700 $89, AC68U $59). Side note is I have T-Mobile and also crappy reception where I live. Will the AC68U give me the same results as the other 2 for $30 less? Thanks for any answers.
The ac68u is more than sufficient, & if you use t-mobile version will give you clearer wifi calling with t-mobile cell service. It's firmware was updated 12/31/17 for krack attack. probably the last update. you can also spend 3 hours to flash it to ddwrt, but will lose special t-mobile calling. t-mobile ac68u probly good for couple of years
