sfx2000
Part of the Furniture
Saw this over in the TP-Link support forums...
What this package does - allows one to enable/disable powersave mode on the TP-Link homeplug adapters.
https://digiex.net/threads/tp-link-homeplug-powerline-power-save-switch-tool-download.14554/
Can't confirm if this works - if you try this, need to attach to each node directly and apply the patch.
Grab both packages - the primary, along with the MS VC Redist package. Windows 10, you'll need to install the VC Redist package first, then switch powersave tool.
Note - must have the TP-Link powerline utility installed as this is a pre-req so that the tool can see the adapter.
