First, thank you all for years and years of helpful info...
I have an Asus AiMesh setup in my house 5300 feeding two 68us...wall are thick and created issues with wireless communication between devices. I originally used some AV500s for wired backhaul but kept having issues with them locking up at and needing to be reset at the most inopportune times...argh.
Did some research and got the LanPort2000 set as well as the TPLINK 9020p kit to test back to back...TP link won with speeds consistently over 200-300Mbps and a much better app to see link speeds etc.
I only really need 3 of the AV2000s for my setup, what are your thought on using the 4th one in a room between my sending unit and the room with the slowest speeds and not connecting it to anything? Will the 800Mbps connection between the 3rd (problem room) and the 4th (next bedroom over and nothing connected to lan port) help me or hurt me overall? That 4th one is also showing a 600Mbps connection to the 2nd AV2000....the sender unit is in room over garage and the farthest away from the other 3...
Thanks for the help and advise!
JW
JW
