*** Revised *** as I had mis-stated part of the issue late last night.
Hello,
I'm hoping someone can point me in the right direction, as I am experiencing some intermittent latency issues.
My current home network is rather simple:
Comcast Cable ISP - Arris SB6190 Cable Modem - Asus RT-AC68W (routing only, radio disabled - Two WAPs: Ruckus R510 Unleashed - Computer and other devices
I have been running some simultaneous pings:
1) Computer to RT-AC68W (192.168.110.1)
2) RT-AC68W to 8.8.8.8
Often I will see intermittent latency only in reaching the AC68W, and not from that router to the public internet, so the issue is primarily inside my network.
Are there any suggestions as to how to track down these intermittent latency issues that appear between client and router? They may come a few times per day to a few times per hour for 2-15 seconds (usually 2-4 seconds).
Note: R510 backhaul is copper, albeit somewhat temporary during construction.
*** Pinging AC68W Router ***
64 bytes from 192.168.110.1: icmp_seq=45310 ttl=64 time=2.060 ms
64 bytes from 192.168.110.1: icmp_seq=45311 ttl=64 time=1.650 ms
64 bytes from 192.168.110.1: icmp_seq=45312 ttl=64 time=1.695 ms
64 bytes from 192.168.110.1: icmp_seq=45313 ttl=64 time=1.894 ms
64 bytes from 192.168.110.1: icmp_seq=45314 ttl=64 time=1.906 ms
64 bytes from 192.168.110.1: icmp_seq=45315 ttl=64 time=1.778 ms
64 bytes from 192.168.110.1: icmp_seq=45316 ttl=64 time=1.226 ms
64 bytes from 192.168.110.1: icmp_seq=45317 ttl=64 time=2.167 ms
64 bytes from 192.168.110.1: icmp_seq=45318 ttl=64 time=102.809 ms
64 bytes from 192.168.110.1: icmp_seq=45319 ttl=64 time=84.141 ms
64 bytes from 192.168.110.1: icmp_seq=45320 ttl=64 time=129.883 ms
64 bytes from 192.168.110.1: icmp_seq=45321 ttl=64 time=174.500 ms
64 bytes from 192.168.110.1: icmp_seq=45322 ttl=64 time=217.535 ms
64 bytes from 192.168.110.1: icmp_seq=45323 ttl=64 time=2.311 ms
64 bytes from 192.168.110.1: icmp_seq=45324 ttl=64 time=1.705 ms
64 bytes from 192.168.110.1: icmp_seq=45325 ttl=64 time=2.321 ms
64 bytes from 192.168.110.1: icmp_seq=45326 ttl=64 time=1.850 ms
64 bytes from 192.168.110.1: icmp_seq=45327 ttl=64 time=24.571 ms
64 bytes from 192.168.110.1: icmp_seq=45328 ttl=64 time=1.087 ms
64 bytes from 192.168.110.1: icmp_seq=45329 ttl=64 time=22.003 ms
64 bytes from 192.168.110.1: icmp_seq=45330 ttl=64 time=66.968 ms
64 bytes from 192.168.110.1: icmp_seq=45331 ttl=64 time=114.486 ms
64 bytes from 192.168.110.1: icmp_seq=45332 ttl=64 time=158.457 ms
64 bytes from 192.168.110.1: icmp_seq=45333 ttl=64 time=203.071 ms
64 bytes from 192.168.110.1: icmp_seq=45334 ttl=64 time=1.553 ms
64 bytes from 192.168.110.1: icmp_seq=45335 ttl=64 time=1.517 ms
64 bytes from 192.168.110.1: icmp_seq=45336 ttl=64 time=2.417 ms
64 bytes from 192.168.110.1: icmp_seq=45337 ttl=64 time=2.030 ms
64 bytes from 192.168.110.1: icmp_seq=45338 ttl=64 time=1.531 ms
64 bytes from 192.168.110.1: icmp_seq=45339 ttl=64 time=1.525 ms
64 bytes from 192.168.110.1: icmp_seq=45340 ttl=64 time=1.387 ms
64 bytes from 192.168.110.1: icmp_seq=45341 ttl=64 time=1.225 ms
64 bytes from 192.168.110.1: icmp_seq=45342 ttl=64 time=2.367 ms
64 bytes from 192.168.110.1: icmp_seq=45343 ttl=64 time=2.052 ms
Hello,
