Traditional QoS for Zoom?
I believe you'll find (once you search this forum) that people either gravitate to CakeQoS or FlexQoS rather than the versions implemented by asus.
They do the same thing, slightly differently, but similarly well: Flex allows you to filter, cake is for an overall method.
I use cake - your router may not support it, or you may not feel comfortable with the command line.
You can try a rule for Zoom that captures udp ports 8801-8810.
