Description:
Enabling Traditional QoS kills throughput for traffic to/from the router itself (eg. built-in FTP server). By "kill", I mean getting throughput of ~100KB/s, whereas with QoS off I'm getting > 20MB/s. Traffic from LAN devices to the internet, or LAN devices to other LAN devices are affected, but nowhere to the extent I see with LAN to router traffic (eg. LAN to LAN I only get 30-40MB/s). This is all over a wired connection and I can reproduce issue with the latest stable firmware and after a factory reset (see steps to reproduce).
What's strange is that this issue appears after a fresh reboot, but logging into the web interface and navigating to the QoS page somehow fixes this. I traced it down to the /getTraffic.asp url. In other words, after a reboot I get slow speeds, but I get much faster speeds if I log into the web interface and visit only the /getTraffic.asp page. The speeds are nowhere as good as the non-QOS speeds, but I'm guessing that's from the inherent overhead of QoS. Furthermore, not connecting the WAN somehow causes the issue to not appear, independently of the /getTraffic.asp fix.
I searched around the forums and it looks like Traditional QoS is fundamentally broken or something and it's hard to fix. Since visiting the /getTraffic.asp seems to fix it, is it possible to add a workaround by automatically visiting that page, or better yet calling the underlying function of bwdpi_status() on startup?
Steps to reproduce:
1. navigate to the firmware update page and upload RT-AC68U_386.3_2.trx (current stable version)
2. after upload success, perform factory reset (using the hold WPS button method https://www.asus.com/support/FAQ/1039077)
3. go through the setup wizard as normal (router mode, DHCP mode for WAN, WAN cable is plugged in).
4. log into web ui, enable built-in FTP server
5. perform speed test by downloading a file from the built-in FTP server [I get around 30-40MB/s throughput at this step]
6. enable traditional QoS (this causes a reboot)
7. perform speed test again [I get 100KB/s download at this step]
8. log into web interface, visit the /getTraffic.asp page
9. perform speed test again [I get 30-40MB/s at this step]
Expected results:
I get good speeds (ie. not 100KB/s) from the router at all times, even after a fresh reboot
Actual results:
I get crap speeds from the router after a reboot, unless I visit the getTraffic.asp in which case it's magically fixed.
Steps to reproduce:
Expected results:
Actual results:
