Traffic Analizer trouble with Transmission
Emmanuel_m41
Hi guys. I have just a simple question.
Will the Traffic Analizer show data downloaded by the Transmission app? I installed it with Entware repo some days ago. I have been downloaded some movies, but i don't see that in the graphics.
Thanks a lot!
I don't know. The Traffic Analyzer is closed source, so the only way to know would be for someone to test it.
You should see it under "Traffic Analyzer/Traffic Monitor" - it's included in the summary of all "Internet Connection (WAN)" - select "Last 24 hours".
At least I saw it when I was using Transmission on my main router (now with Deluge its the same).
I will perfom some test latter and upload some images of it. However, i can assume the Traffic Analyzer/Statistics does not show the own router traffic.
As you can see, it's included in the summary as you say, but i dont see this traffic under "Statistic". Thanks a lot!
Here you can see some pictures i get from the router.
You probably don't want to post screenshots of illegally downloaded TV shows.
