Traffic Monitor for 5GHz not working?
Livin
I just started having issues with what acts like the network being saturated. Rebooting the router does not fix it, thus I suspect something in my network is hammering the router.
I can see tons of stuff on the Internet and 2.4GHz tabs but nothin-zippo-zilch on 5GHz, which is odd since I have 3 devices connects 24x7 to that radio, and a PC running XBMC on it also.
Even showing device specific Realtime, while I'm streaming a 720p video - the monitor shows ZERO traffic to that IP, but is shows 5 connections?
running Merlin 374.43_2 (so I can keep 500 Tx power and other tweaks)
thanks
thanks
Much better than my N66U. you got Internet and 2.4GHz.
Mine is nothing...and so far still cannot figure out the any possible solutions...
picture.php
UPDATE: end up it is due to Chrome issue. problem solved by using IE:)
I also have no traffic monitoring of the 5Ghz band. Tried Firefox V34.0.5 and IE 11 browsers to no avail.
Merlin Firmware:376.49_4
Works fine for me on 5Ghz tab with Safari 8 and Chrome 39.
