Traffic statistics not working on Asus RT-AX3000
Tailsrules723
I enabled the traffic analyzer but its not recording any traffic. Is their any way i can fix this?
How long did you let it run before that screenshot? Which firmware? What scripts are you running?
Do you happen to have NAT acceleration enabled (for my RT-AC68U, it's under LAN->Switch Control)? If so, disable it, reboot, and try again.
Delete the history. It will start working
Not really, it freezes on many Asus router models, not just on yours. Restart usually fixes it temporarily.
There is no NAT acceleration control in LAN, Switch Control on your router and it's unrelated to the problem. Asus has to fix it upstream.
As a fellow SNB member says - wait for Asuswrt base update, then wait for Asuswrt-Merlin update, then wait for GNUton Asuswrt-Merlin fork update.
