traffic stats to USB problem
besticles
I'm having some problems getting my traffic stats to save to my usb stick. It seems to update the files every hour but it resets them after a reboot. I have a RT-N66U with build 3.0.0.4_266.23b. I attached a couple pics of my configs.
It looks like the router is resetting the data files???
The datafile reset probably only happened after your next reboot.
I attached 2 screen shots. The first is the graph before a reboot... the 2nd is after the reboot. If I have everything setup correctly shouldn't the graphs display the same information??? The after reboot graph is blank, like nothing was actually saved to the USB stick. I have been assuming that the graphs would still be populated after the reboot if the datafiles were actually being saved on the USB stick.
Check the System Log, it will report if it had trouble reloading the data file.
My logs looked ok.... So I tried a couple other things, one of them must have worked. First I factory reset the router then I formatted the USB stick as ext3 (it was FAT32). I'm assuming the factory reset fixed it, I forgot to do one after upgrading from the stock firmware. All the stats remain after a reboot when viewing Daily/Monthly charts. The only thing that doesn't show up is the graph on "Last 24 Hours". The graph still seems to reset itself after each reboot... I'm not concerned about the graph, all the information I want is now saving. Thanks for your help.
Last 24-hours: that's normal. To avoid making the data file insanely large, the data file only contains daily data, not hourly.
